Item Condition: Good. Used about twice a year for the last 5 years
Reason for selling: Dont use enough.
Price: $700 neg.
Payment Method: Pickup - Cash, Paypal, COD Only
Extra Info:I have owned the gear for about the last 5 years. they have always been housed in the roadcase, and always looked after. I paid in excess of $1800 when I bought them. i have checked everything is functioning perfectly. Comes with all leads and RCAs. Simply plug and play!
Pioneer DJM300S Pro DJ Mixer
FEATURES
- Auto BPM Counter: The Beat-Per-Minute counter is capable of accurately measuring the BPM of almost any kind of dance music automatically. This function includes a digital indication that allows you to confirm the tempo of the current selection at a glance and takes the guesswork out of comparing the beats of different selections. In addition, the DJM's BPM counter works equally well when monitoring CD player and other digital sources or analog sources such as a turntable
- Separate -26dB 3-Band EQ for Each Channel: The DJM-300S is equipped with separate 3-band (High/Mid/Low) EQ that allows the DJ to adjust the output of each channel independently at the turn of a dial. By enabling attenuation of up to -26dB, the system makes it possible to effectively silence unwanted channels or adjust each channel's output level exactly as desired. Pioneer has also included a separate +12dB boost capability for each channel for when you want to add emphasis to particular sections
- Fader Start Play: Connecting the DJM-300S to the CDJ Series allows you to take advantage of Fader Start Play; by increasing the Fader, on the mixer, the player will automatically override the Pause control and start the music immediately. Fader Start Play also works during Cross Fading, an industry first that brings out the best of sampler-style music
- Fader Back Cue Play: When the DJM-300S is used with the CDJ Series, the Fader or Cross Fader controls can also return you automatically to a designated cue point if desired. By fading Cross Fader back and forth or Fader up and down quickly, you can give the ""essence"" of scratching a certain point on a vinyl record
- Headphone Monitor Switching Function: This handy function makes sound source monitoring more convenient and flexible than ever by allowing you to switch easily between all-channel stereo, all-channel mixed stereo and all-channel left/right distributed monitoring
- Trim Function: Separate Trim controls allow you to perform flexible compensation by individually raising or lowing the input level for each channel to enable almost effortless mixing of selections recorded at different signal levels
- Equalizer-Equipped Microphone: The special equalizer controlling the microphone input means you can set the EQ to HIGH to give your voice greater clarity and presence, or to LOW to enable a variety of microphone sound presentations. Moreover, the EQ can also be used to compensate for feedback or burst sounds
- Phono/Line Switchable Inputs: Using the rear-mounted switches, the rear PHONO inputs can be used as line-inputs to allow the connection of a number of sound-source combinations. In short, the DJM-300S allows even DJs who don't use an analog turntable to make flexible use of four separate sound source inputs
- Master/Channel Level Meter: During normal operation, the DJM-300S's level indicator displays the Master output level. When the Master/Channel Level button is pressed, the input level of each channel can be displayed in turn for quick confirmation of the current channel level input status
- Input Terminals: CD x 2 (RCA), Phone x 2 (RCA) (Switchable to line), Mic x 1 (1/4"" Phone)
- Output Terminals: Master Out x 2 (RCA), Headphone Monitor x 1 (1/4"" Phone Jack)
- Frequency Response: 20 Hz - 20 kHz (CD)
- Signal-to-Noise Ratio: 80 dB or more (CD)
- Total Harmonic Distortion: 0.05% (3v RMS) or less (CD)
- Power Requirements: AC 120v, 60 Hz (US, Canada)
CDJ 100s
Digital Jog Break
Equipped with 3 remix assist functions (Jet, Zip and Wah) and a Digital Jog Break dial, a new remix world can be experienced. By operating the jog dial in time with the music, you can create original sound effects.
Jog Dial
A large 3.9 inch diameter jog dial enables quick and easy corrections to uneven beats with only a touch.
• PITCH BEND
This function changes the music tempo depending on the direction and speed the jog dial is rotated.
• FRAME SEARCH
Moves the pause position in frame units (1/75 sec) when the jog dial is rotated in the pause mode.
• SUPER-FAST SEARCH
By turning the jog dial while holding down the manual search button or the track search button, disc searches can be performed faster than normal search or track search functions.
Tempo Control
3.9 inch long, high-precision slider allows for easy tempo adjustment. With a digital display calibrated in 0.02% units (within a +/- 6% range), tempo adjustments can be made more easily and accurately.
• TEMPO CONTROL RANGE
The maximum range can be set to two variable ranges; +/- 10%, +/- 16%, to provide easier operation environment.
• MASTER TEMPO
Maintains the same pitch of sound while changing the music tempo.
Cue
• BACK CUE
After storing a cue point in memory, press the CUE button while playing back a track to return and start from the stored cue point.
• AUTO CUE
Skips the non-recorded part at the top of a track and automatically enters stand-by mode at the track's starting point, allowing playback to begin instantly when the PLAY/PAUSE button is pressed.
Fader Start
By connecting this unit to the DJ mixer DJM-300, the QUICK START function can be performed by using the mixer's fader function.
Pictures:
Click to view attachment
