Full Version: HIFONICS GOLIATH 3212 IDEAS NEEDED
GONE NUTTS
Hi to all,
need some help to wire quad voice coil subs.
i have two subs in total with each coil beeing at 2ohms!
Also need some tips in building an spl enclosure for the hifonics sub.
Not sure what amps to run, some ideas would be good.
Hifonics Goliath Subs are rated @ 3200 wrms.
Cheers!
Charger
The quad coils are easy to wire. A single 1ohm load is probably the most usable final load.
YT1987
yea 1-ohm load would be best, unless you find an amplifier that is stable at .25ohm, if you are using it for everyday driving of course if not then look at the Hertz HP1KD amplifier 1ohm will be 3200wrms.
