Let me ask. Do you think cars that have frameless windows (eg Subarus) are at a disadvantage when it comes to SQ/Comp car audio? When compared to cars that have full framed windows.
I think that there is a difference, minimal, but it is there. The glass has alot more room for wobble considering it sits on a rubber wedge. More often than not were placing larger/beefier drivers in the doors, hence I would expect these to shake the glass alot more. Were putting 9's in doors now! Lets accept that a tougth/held panel is better, in more cases than not, then a panel that has room to move. Even if it's minimal.
You could argue against that; in that if you prep/deaden your door correctly you would not have that issue. That the deadness of the door would not let any energy transfer to the glass in the first place. Also the fact that there is no flimsy frame lets the glass sit correctly wedged in the rubber as it should. As what is stoppin the window frame from moving...
Discuss.
ps, im considering a car purchase and "might" use it in the future for SQ/Comp. I also posted this on another forum, but value your opinions too.
