There is no comparison between the two units IMO
Bremen
DSA Max (DigitalSoundAdjustment)
Dynamic Noise Covering (DNC)
Self-calibrating equalizer
Number of channels/bands 4/27
Sound-/ Hall effects
Runtime adjustment
Active 2-way frequency devider
High-pass filter separate for front/rear
Source-specific sound settings
Sound presets (music)
X-Bass with variable center frequency
Preamp-Out 4-channel (5 V), gold plated
Internal power amp on/off
Aux-In 2
Sub-Out: var. gain/frequency
Center out (adjustable)
RMS power (DIN 45324) at 14.4 V 4 x 26 watts
4 x 50 Watts Max. Power
Look at the specs
It only has 4 channels for starters (the Eclipse is 6 channels) which is near useless for getting decent control over a system (for a unit that's aimed at SQ setups), means if you want to run rears you'll have to use RCA splitters and set your sub xover through the amp no biggie but can make it a pain when wanting to fiddle with settings quick and easily.
It has no ability to run a bandpass from what I can see.
The Eclipse has 24 bit DAC's
The Eclipse has Time Alligment, no mention of this with the Bremen.
The Parametric EQ in the Eclipse is alot more flexible in my opinion.
Thing is the Bremen has been out for several years now and there's a reason why you never see anyone using them, although it can look good at first glance, the unit IMO is fundamentally flawed by basic things like no Time Allignment and not having a proper 6 channels out and not to mention a poor CD mechanism, which cannot be argued because Blaupunkt have always had a CD mechanism that is below average at best they skip notoriously, and are extremely bad with scratched cd's, and they've been like this for years.
Luke
QUOTE (Alpinewhite iS @ May 15 2008, 04:25 PM)
Saw a review in Incar magazine as a highly reccomended unit under $1000. FHRX reccomend it in better systems so it can't be too bad.
It's going in a German car so like keeping it German
It's a magazine, and FHRX are a Blaupunkt dealer there not going to call it bad.
All Blaupunkt stuff of recent years comes from Thailand and the like, so not what I'd call German.
Don't take me as a Blaupunkt hater, I actually like the brand, my first Car Audio gear was Blaupunkt, and the amp I have has been through hell and back, and I actually was quite excited when they first released the Bremen, to be dissapointed when I did more research and it appears the CD mechanism still has it's fault, I wish they would release a unit that isn't flawed in some way.
