High Performance Power. High Performance Style.
Introduce yourself to more Watts for your high-performance dollar. Polk Audio proudly introduces a new line of high-power amplifiers from the budget-minded enthusiast who wants uncompromising performance from their cars sound system to the no holes barred audiophile that wants competition winning performance. These new amplifiers are styled to look as visually appealing in a super tuned import as they will in a gutsy American big-bore. Our new amps come in 2 channel, 4 channel, and a monoblock configurations, as well as an all in one 5 channel model that enables you to drive all your speakers and a subwoofer.
Click to view attachment
Three different power output monoblocks are available, in 400w RMS x 1 (1 Ohm), 600w RMS x 1 (1 Ohm), and 1200w RMS x 1 (1 Ohm) configurations.
PA400.1/PA600.1/PA1200.1 - Monoblock Amps
- 1 Ohm stable.
- Anodised extruded brushed aluminium cover for optimised heat dissapation.
- Cast aluminium end caps for optimised heat dissipation.
- Impressive solid aluminium logo and model panel back lit in cobalt blue.
- Super effiecent Class D PWM design runs much cooler than conventional amps.
- High speed MOSFET switching power supply.
- High-current complementary Class D MOSFET ouputs stable into 1 Ohm loads.
- Thermal, DC offset, reverse polarity and short circuit protection.
- Master/slave function supports two amps birdged into one load (PA6001./PA1200.1)
- Full crossovers and Phase Adjustments.
- Remote subwoofer level control function.
- Rugged heat sink.
- Stainless steel mounting hardware with rubber isolation grommets.
- Unity gain pass-through RCA jacks with buffered output.
PA250.2 (2/1 Channel Amplifier)
125 watts x 2 (2 ohm) continuous power, 200 x 2 (2 ohm) dynamic power, or 250 x 1 (4 ohm) continuous power.
CEA-2006 Compliant specifications for true, accurate power ratings.
PA200.4 (4/3/2 Channel Amplifier)
35 watts x 4 (2 ohm) continuous power, 80 x 4 (2 ohm) dynamic power, or 100 watts x 2 (4 ohm) continuous power.
PA500.4 (4/3/2 Channel Amplifier)
125 watts x 4 (2 ohm) continuous power, 250 x 4 (2 ohm) dynamic power or 250 watts x 2 (4 ohm) continuous power.
PA1100.5 (5/4/3 Channel Amplifier)
125 watts x 4 (2 ohm) and 600 x 1 (1 ohm) continuous power; 250 x 4 (2 ohm) and 1200 x 1 (1 ohm) dynamic power.
Recommended Retail Prices for PA Amplifiers are from $449.00 to $1249.00 AUD.
Polk Audio PA Amplifiers are now available and ready for purchase through Authorised Australian Polk Dealers.
For your nearest dealer, please contact Directed Electronics Australia.
