QUOTE (BryanM @ May 21 2008, 07:56 PM)
hey Ben,
I actually saw your thead and read every entry (right up until you sold your car
I am thinking of ging for forward facing subs tbh, as it gives me 2 advantages, namely it protects my subs from weekly shopping and what not (still a family car) and lets me put windows in it like yours, for some really nice lighting effects.
Just 1 question, did your ski hole have to be open to get good sound out, and if I remember correctly, you had a ported box firing into the ski hole?
Also, how far did you put the box behind the seat?
Thanks for the help,
ps, you don't have the old box lying about do you?
I noticed a definate increase in spl with the ski hole open, but it only measured a difference of 2-3dB on the termlab. The ski hole flap (plastic thingy) was eventually removed as it clearly was being slowly destroyed by the air mass moving through the ski port.
One thing I will mention about the box setup is that I packed copious amounts of quilt wadding around the box edges so the front of the sub enclosure was completley sealed from the rear cabin, and this "felt" like it was helping the low end freqs stay inside the cabin area, and I noticed my shirt sleeve would resonate slightly more whilist sitting in the driver's seat, as compared to the box without the wadding. All I can think is that the wadding stopped the pressure wave from escaping out into the boot, however on the termlab there was absolutely no diffrerence in spl, so it may have been my mind juz playin tricks....
Unfortunately I don't have the box anymore, but if I rumage around in my old photo folder I may be able to find a photo of the box before I installed it... The box is actually in "lucifer's" magna atm, with the infinity subs now getting over TWICE the amperage as they were in my old setup. Absolutely deafening to say the least!!!
Lucifer (luke) has made his own install thread on AMC featuring the sub box (in the member's machines section), and if I can't find any photos from when I had it, I'll remind myself (or Luke) to take some when we wire up the blue lighting LEDS...
The box face was virtually pressed right up against the rear seat, leaving only a 10 cm gap for the subs (which were slightly recessed) to pump through. Quilt wadding was packed around the edges as tight as possible, as well as along the top of the sub box, effectively making the sub box front face air sealed from the boot. This also stopped the rear seat from resonating, and forced the resultant wave from the subs to "shoot" forward through the ski hole. I experimented with this gap, and found that any tighter than 10cms made the subs starve for air to pump (you could hear the ski port chuffing), and on the other hand you tended to lose a fair bit of SPL if the gap was larger (as the resonance from the rear seat interacted with the subs), and by 20-25cms from the sub face panel to the rear seat panel a noticeable drop in sub freqs from 40Hz down was evident (by nearly 6dB).
Good luck on your setup, if you do it right you'll get nothing but pure bass, with absolutely no drone at all, just the feeling like your gonna crack your chest in half!!!!
I went for a late night lap with Lucifer last Sunday. Forgot how sexy it was listening to those subs at full blast, I've yet to be able to get anywhere near to what the old setup sounded like with my new car. Fast, detonating bass pulses that made you cough uncontrollably .... Godamn I miss the ol' magna
Damn it man!!! Now I'm fricken starting to cry!!!!
I wantz my magna back....
