Hello all!
It is with great joy and excitement that we announce that the latest shipment of SPLDYNAMICS has arrived and is available for sale in Australia.
We now carry the XTR range of subwoofers which comes standard with reinforced carbon fibre cones and heavy duty baskets.
Each XTR series is at home in a conventual mount or as an inverted mount to display the chrome finish of the base.
The series includes the:
10 inch dual voice coil 2 ohm rated at 1200w (600wrms) $350
12 inch dual voice coil 2 ohm rated at 1500w (750wrms) $400
15 inch dual voice coil 2 ohm rated at 2000w (1000wrms) $450
Also to hit our shores is the heavy hitting HF series 6.5inch mid range drivers, these components are specially designed to be used in demanding car audio as an active system.
Each of these 200w (100wrms) woofer are rated at 3 ohm and are fitted with a large 3in voice coil (same size voice coil of most 15in subwoofers!) for efficient cooling.
The HF series is available with a separate 28mm Silk Dome tweeter which carries an extremely powerful neodymium magnet.
We look forward to some long heavy testing of these tuff little units,
Price for the set $230
Woofers only $180
Tweeters only $50
To further extend our range of audio products we also carry the new SD series of component sets, these slick and sensibly priced kits come complete with crossovers and all wiring hardware including 3 options of mounting for each tweeter.
Each 6.5inch driver incorporates a single cast basket and a slick silver unmarked cone.
These sets are rated at 160w (80wrms) and will complement any build or system
SD6.2 sets $150
I will list some pictures as soon as i unload the camera!
Spldynamics Australia
