QUOTE (syd-monster @ Jun 20 2008, 10:50 PM)
Louis,
can you explain the problem with the a-pillars a little better...
are you covering the pillars with vinyl?
or laying up over the factory vinyl on the pillar?
maybe its me but Im a little confused (not that ist hard to do
but the tweet mounts look great so far mate!!
Hey syd-monster.
So, I built my A pillar mount off the factory vinyl. I roughed up the vinyl with 80G sand paper. and Hot glued strech fleece onto it, I than glassed and filler it. (FINISHED) Then I realised the hot glue did not stick to the vinyl strong enough, hence it started to lift/ detach. So, I dremeled the peeling parts. So now my question is, SHould I glass over to fill in the gap or should I just filler in between the gap.
I think will lightly glass over the gap then fill it , The filler itself may not adhere to the vinyl. I am so tempted to use silicon to fill in the gap. But paint might not adhere of silicon
