Hello all!
It is with great joy and excitement that we announce that the latest shipment of SPL DYNAMICS gear has arrived and is available for sale in Australia.
We now carry the XTR Series Subwoofers, which come standard with reinforced Carbon Fibre cones and heavy duty baskets.
Each XTR Series Subwoofer will be at home in a conventional mounting application, or inverted to display the polished chrome finish of the motor assembly.
The XTR Series includes:
XTR-250D2 - 10" Dual Voice Coil 2 ohm - rated at 600wrms (1200w max) - selling for $350
XTR-300D2 - 12" Dual Voice Coil 2 ohm - rated at 750wrms (1500w max) - selling for $400
XTR-380D2 - 15" Dual Voice Coil 2 ohm - rated at 1000w (2000w max) - selling for $450
Also to hit our shores are the heavy hitting HF Series 6.5" Components. Composed of the 6.5" HF-6.1 woofer, and the 1.1" HF-1.1T Silk Dome tweeter. These Components are specially designed to be used in demanding car audio systems, such as 'Full Active' systems.
Each of the 6.5" woofers are rated at 3 ohm impedence, can handle 100wrms (200w max), and are fitted with a large 3" Voice Coil for efficient cooling. (Same size voice coil of most 15" subwoofers!). The 1.1" Silk Dome tweeters are rated at 60wrms (120w max) and feature powerful neodymium magnets, and a neat mounting kit for flush, angle or surface mounting.
We look forward to putting them through their paces, with some heavy testing of these tough little units.
HF-6.1 + HF-1.1T Set (No Passive crossovers) - $230
HF-6.1 (Woofers only) - $180
HF-1.1T (Tweeters only) - $50
To further extend our range of audio products we also carry the new SD Series Component sets. These slick and sensibly priced kits come complete with passive crossover networks, all wiring hardware, and a mounting kit for flush, angle or surface mounting the tweeters.
The SD-6.2 Component set features the 6.5" SD-6.1 woofers that incorporate a heavy duty die cast basket and a slick silver one piece, unmarked cone, with rubber surrounds. Also included is the 1" SD-1.1T Silk Dome tweeter with neodymium magnet. Rated at 80wrms (160w max) the SD Series Components will complement any build or system.
SD-6.2 Set - $150
Pictures will follow as soon as I unload the camera!
Thanks,
SPL Dymanics Australia.
