vs380kw
Jun 26 2005, 05:17 PM
hey guys my handles rattle in my vs commo and i cant seem to stop them!! how can i fix this besides ####ing super super glueing the handles coz there are bloody annoying ??? cheers vs380kw
~Spyne~
Jun 26 2005, 06:39 PM
you mean the exterior door handles?
i have the same problem with my front passenger handle (vr acclaim) and as yet, have not been able to think of an easy solution, so come on ppl, help some 'brothers' out here!
vs380kw
Jun 26 2005, 07:28 PM
yeah its the exterior door handles two froont door as back ones dont have speakers in them its a wagon
LexARSE
Jun 27 2005, 06:48 AM
My handles on my VS wagon used to rattle to. You can try getting some stick on rubber/foam thats thick enough to get under the handle. It helps a little bit but there still there.
Pakman
Jun 27 2005, 04:19 PM
yep i have that problem too, man how crap is it. vs caprice, rattles on passenger side but not the drivers side. you say go wagons, used to have a vn wagon, its door handles never buzzed at all. Fa who cares now it got stolen. Bloody wankers.
Damo95
Jun 27 2005, 05:08 PM
hahaha..
must be a common problem with the commodores, as mine used to rattle when i had my previous setup in there.. im dreading the time i fire the IDMAX up..
out of the whole car, only 3 things rattle.. the bumper, numberlate (altho slightly and fixable) and then damn handles.. :/
i was told sponge is the way to go, gotta try it when i pull the trims off to do the inserts..
USER486
Jun 27 2005, 06:27 PM
I'm guessing that the handles use a spring to bring the handle close again after you open the door right? If so mabey this spring is a little week from factory and could be upgraded to a stronger one? Only result should be a firmer door hangle when it comes to open in and it not being so seceptible to vibrations. I'm speaking from ass here but it could be something to check?
vs380kw
Jun 27 2005, 06:42 PM
yeh im not gonna waste any more time with the handle im just gonna take it to doran and let them work there magic
Jun 27 2005, 06:46 PM
stronger spring, or a bit of sticky foam tape in the mech. will help it to 'nestle' into place more snug.
I wish it was warmer, my fingers are ceasing up
CVBASS
Jun 27 2005, 07:04 PM
shave the handles off and get remote operated solenoids to open the doors
Jun 27 2005, 07:23 PM
or silicone bead the edges of ONE of two surfaces that contact.
make sure it cures when they arent contacting.
voila. Silicone surround on one of the surfaces absorbs vibration. May be difficult to make it look neat.
Jun 27 2005, 08:52 PM
The VN's had plastic handles where as the VR/VS's use metal handles.
Go buy some VN handles in the same colour from the wreckers if your worried.
Timm3h
Jun 27 2005, 08:53 PM
must be a VR/VS thing... I have a VN, and dont have that issue. knowing the inside of the door, I reckon some thin foam and bend the standard spring a little to give a firmer hold.
SILVR6
Jun 28 2005, 09:16 PM
I just thought that then i read your post
My VN has no problems with the handles but just about everything else rattles, used to have numberplate problems, but they got fixed with some 6mm rubber behind it.
Timm3h
Jun 28 2005, 09:40 PM
Silvr6, how did you stop the rear garnish vibrating to hell?
