D34M0N
Jun 21 2008, 11:00 PM
Ok i got a single 12" SPLX Quad 1ohm sub with a 750w RMS and 2000w DB burst rating and plan to get a second one down the track. With 1 i can wire it to 1000w RMS @4 ohm and with 2 i can run them at 1500w RMS @ 2ohm (750 each at there rated power) or 2000w RMS @1ohm (Effective 1000w rms each) was just wondering has anyone ran these at over there rated power or no of anyone who would know etc? As i would think they could handle 250w rms more being a SPL sub but don't wan't to break them. Going from Kicker Comp's to this i can't afford to break them.
Heres the Spec's from SS
Specifications
dB Burst Rating (Watts): 2000
RMS Power Handling (Watts): 750
Magnet Weight (Oz): 192
Freq. Resp (Hz): 24 - 1.4K
Fs (Hz): 35.2
Qes 0.342
Qms 5.387
Qts 0.322
Vas (Ft3) 1.423
Xmax (Inches) 0.565
SPL (dB) 98.2
Hole Size (Inches) 11.25
Woofer Depth (Inches) 7.25
In a 3.5 CuFt3 box tuned at 45hz using slot port.
Charger
Jun 22 2008, 04:13 AM
We ran the 15" version daily off a Rockford T40001bd that was birthsheeted at 4900wrms. It obviously found the limits of the woofer very fast but none the less it still ran for short periods. I'd say a safe power level would be around 2000 watts.
D34M0N
Jun 22 2008, 10:32 PM
Ah yeh then i should be right with 1000w
Thanks for that even though it didn't handle heaps of power did it go loud? Was thinking iff not i might try get a Phoenix Gold Ti12D Elite like one of the other guys just got as they have some nice specs and 4" excursion yum.
Charger
Jun 22 2008, 11:05 PM
My friend did 146dB @ 38Hz with just one in his Pajero 4WD. It took the power but it found the thermal limit in a matter of seconds. They actually have pretty good mechanical power handling with multiple stiff spiders and a strong cone, he fibreglassed the back of his cone to stiffen it. If in a good box I don't see why they wouldn't take a sheet load of power for burps. The one thing I would be wary about is the glue, not that it's too bad. Just not what you'd find on a rock solid woofer like DD or RE. The SPLX is a China woofer.
