QUOTE (Komodo @ Jun 23 2008, 12:51 PM)
Rotors depends how mechanical you are. I have done it in the past - but I now pay someone.
As for 4wd and LPG...
What are you looking for. Something to take you along mild tracks or something a bit more extreme?
You looking at how old of a vehicle?
tray or wagon?
LPG tanks normally affect departure angle cause they are fairly low slung.
They take a fair beating though.
You looked at diesel gas fumigation? Ecconomy of diesel with the power of a petrol motor. Plus you get to keep both tanks as well as the LPG tank. Plus it doesnt affect clearance other than a slight loss of ramp over- but thats easily rectified with a small suspension lift.
Mum and dad have had both a GU and an 80 on LPG in the past and the GU was HEAPS better on fuel than the LC80. The LCs are full time 4x4 and only have a centre diff lock and out of the box arent as good off road.
The patrol GQ (efi) and GU are better ecconomy because they are part time 4x4 and have a locked transfer (ie 50 / 50 split when 4H or 4L is engaged) they also have a LSD from factory so you can be assured you will always have atleast 3 wheels driving.
GUs also dont suffer from IFS they have live axle front end.
I would avoid the 3L diesel. 4.2t is the way to go or the newer 3L CRD seems to be on the money and not much of a grenade.
the 4.8 will cost you in ecconomy but its got a crap load of power.
on the flipside.
LC has more power than the trol and being a Toyota it is over all a better finished vehicle.
Bewarned though LC's pop diffs like they are going out of fashion.
The trols main weak point is speed wabbles - mostly an issue on utes though.
and lack of under body protection (easily rectified by TJM or ARB etc)
The ST up on the GUs have auto locking front hubs - they are a little prone to breaking but a simple swap when they do give way back to GQ manual hubs or AVMs is a good replacement. Other wise plenty of guys take the ball bearing out of the hub and this makes the auto hubs fully manual and thus less prone to damage.
Looking for something more exteme at the moment. No utes. Would be doing a bit of off field work.
Requirements I have are fairly basic, must be able to tow easily (21ft ski boat), get in and out of fairly muddy terrain when launching it (anyone familiar with Wyangalla dam's backwaters will know what I mean when I say muddy). I'd be looking a taking it duning on the sand occasionally, and long road trips / offroad bush trips. Parents have a Pajero DiD and has excelled off road.
Other requirements - must be able to fit a 6'5'' frame, and be sturdy. Was looking at the Landover defenders, they look solid and reliable. Not sure of their off road ability though. Around the 2003 models seem to go for ok money.
