Full Version: Server 2008 - Terminal Service Easy Print help
anyone here know how to set this POS up?
i have been searching the net to get some idea on how to get it working, you would think microsoft would have some sort of help file on it : (
all they have is what it does.
same as everyone else, i know what it does and i want to use it.
is there anyone that can help me??
(i have server 2008. OKI printer hooked up to a Vista machine, access the server via a terminal window, no drivers for the OKI printer for 2008, need TSEP so i can print from out database thats located on the server)
Sigmeister
Fudd, what part is failing? Is it not allowing you to add the driver as the OKI one doesn't exist? Is it picking up the Model as Terminal Server Easy Print?
This page has some good info (Although you have probably been through all this)
http://blogs.msdn.com/ts/archive/2007/05/0...int-part-1.aspx
(pages 2 and 3 are also not bad)
its allowing me to add a driver, just not letting me add the terminal services one :s
Sigmeister
Is your Vista Machine SP1?
It also appears that it needs to be switched on in group policy.
Group Policy settings
The following Group Policy settings have been added for Terminal Services printing:
Use Terminal Services Easy Print printer driver first
This policy setting is located in the following node of the Local Group Policy Editor:
Computer Configuration\Administrative Templates\Windows Components\Terminal Services\Terminal Server\Printer Redirection
The possible values are:
Enabled or Not configured: If this policy setting is enabled or not configured, the terminal server will first try to use the Terminal Services Easy Print driver to install all client printers. If for any reason the Terminal Services Easy Print driver cannot be used, a printer driver on the terminal server that matches the client printer will be used. If the terminal server does not have a printer driver that matches the clie
Enabled or Not configured: If this policy setting is enabled or not configured, the terminal server will first try to use the Terminal Services Easy Print driver to install all client printers. If for any reason the Terminal Services Easy Print driver cannot be used, a printer driver on the terminal server that matches the client printer will be used. If the terminal server does not have a printer driver that matches the client printer, the client printer will not be available for the Terminal Services session. By default, this policy setting is not configured.
Disabled: If you disable this policy setting, the terminal server will try to find a suitable printer driver to install the client printer. If the terminal server does not have a printer driver that matches the client printer, the server will try to use the Terminal Services Easy Print driver to install the client printer. If for any reason the Terminal Services Easy Print driver cannot be used, the client printer will not be available for the Terminal Services session.
nt printer, the client printer will not be available for the Terminal Services session. By default, this policy setting is not configured.•Disabled: If you disable this policy setting, the terminal server will try to find a suitable printer driver to install the client printer. If the terminal server does not have a printer driver that matches the client printer, the server will try to use the Terminal Services Easy Print driver to install the client printer. If for any reason the Terminal Services Easy Print driver cannot be used, the client printer will not be available for the Terminal Services session.
ok had another play yesterday, the only way it will let me add a print driver is by browsing for it. wont let me use the easy print one.
as for changing the group policy settings, how do i get there? i have looked and looked for what is says in what you posted there but i cant find it :S
nothing i have read from MS or anywhere else can give an easy to read, straight to the point step by step guide.
all of them have plenty of info on how it works, but not how to implement it :s
oh the vista machine is SP1
(i also had problems yesterday with that machine, word wouldnt load, outlook wouldnt print, just crash.. even after deleting them and re-installing. had to roll back to sunday to get it to work)
Sigmeister
Sorry I still haven't quite got my 2008 test environment up and running. Hopefully in the next few days.
As for policy, you can check it using the resultant set of policy snap in in an MMC window.
Start => Run
MMC
File => Add\remove snap in
Add
Resultant set of policy
Right click and generate RSoP data
This should allow you to browse the GP settings and it should also tell you what GPO is setting it. Then you can modify the GPO accordingly.
i just noticed that the snapon wasnt installed :s
ok loaded the snap in.
but it's telling me i have have to log in with a domain user account.
i have admin rights and ihave loged in with the admin sign in and it still wont let me play sad.gif
