QUOTE (keepitreal07 @ Jul 28 2008, 10:43 AM)
i been speaking to matt and with my car the 5 with have more dynamics......i had 4" focal's and they not even seem like they were there.
id love to stick with 4" just cause they smaller but a 5.25 would sound nice i think:)
and the exclusive 5" sounds like a good pick. cheaper then the revs
Why on earth would the 5" have more dynamics??? :S
The 4" plays flatter, higher. It'll play smooth as hell up to 5khz if you get the angles right, while the 5" starts losing compusure above 2khz. The better extension on the 4" allows you to cross your mids (and thus your tweeter) hgher which means your tweeters will play cleaner (less distortion) and longer (increased power handling) while also potentially improving imaging and blending by permitting your mids to handle a greater degree of information (via higher crossover point, where youre ears aren't quite as sensitive). I'd also be willing to bet that the 4" will have better midrange distortion characteristics then the 5" versions as well.
The only advantages I can possibly see in the 5" is that it will play
slightly cleaner in the lower midbass (<250hz) and be slightly more senstive (by maybe 1dB, which is insignificant). I don't understand how these will benifit you in the intended application though.
As for the Scanspeak 5", I'd agree with you that it's not worth it. I'm probably one of the few people who have owned the Revelators, HDS and Exclusives (or at least my brother had the Exclusives). I've heard the Exclusive 7" back to back with the Revelator 7", and can tell you right away that the Peerless has a cleaner, more defined, and less coloured midrange. The same will be the case for the 5" versions, and I'd be confident to say the 4" HDS would slaughter both in midrange. Hell the 4" Exclusive would be better again, but these are pretty much impossible to find now days.
As a midbass driver different story - the Revelators slaughter the HDS mids in the bottom end, playing lower, stronger, and with less distortion. You aren't using them for midbass though, so that's really not of any benefit to you (not if you have to sacrifice midrange to get it).
Don't get me wrong, they are all truly brilliant drivers and I'm sure you'll be impressed either way, I just think (with high confidence) that the 4" Peerless will sound the best of all in your application.
