ok i have spoken to a few people but now have to pull my finger out and get it done
I am hoping to afford within a few months when tax comes in.
I will have my behringer DCX2496 running by then as i am waiting on the power supply can cables running from an alpine IVA-W202E
I will be installing my self into a 1998 nissan pulsar Q into the kicks
HAT L1 into the dash like Damo95
And the Peerless SLS8" into the doors.
Most prices are from madi sound and ill get em just a little more then that in aus delivered from work
Now i am sure there are some more...i only really wanna speak under 150 each. but they will cover most of the frequency range(300hz-6k)
Here are my choices
Scanspeak 12m/4631G
$285 each 4.5"
TECHNICAL DATA:
Sensitivity 2.83V/1M 89dB
Free air resonance Fs 75 Hz
DC resistance 3.2 W
V.C. inductance 0.22 mH
Power 40W
Effective cone area 49 cm2
V.C. diameter 38 mm
V.C. height -
Air gap height -
Lin. & max. excursion ±3/ ±7 mm
Air gap flux density -
BL 5.3 Tm
Moving mass incl. air 6.5 g
Net weight 0.51 kg
Outside diameter: 115.5mm
Cut out: 92mm
Depth: 48.4mm
25.4mm = 1" = 2.54cm
Scanspeak 15m/4531K
$222 each 5.5"
http://www.madisound.com/catalog/product_i...roducts_id=1479
TECHNICAL DATA:
Sensitivity 2.83V/1M 90 dB
Free air resonance Fs 35 Hz
DC resistance 3.5 ohm
V.C. inductance 0.17 mH
Power 12dB@Hz 60W
Effective cone area 95 cm2
V.C. diameter 38 mm
V.C. height
Air gap height -
Lin. & max. excursion ±3 & ±8mm
Force factor BL Product 6.0 Tm
Moving mass incl. air 11 g
Net weight 1.6 kg
Vas 24 ltrs
Qms 4.8
Qes 0.24
Qts 0.22
Peerless PPB 830860
~$50 5.25"
http://www.madisound.com/catalog/product_i...roducts_id=1608
Peerless 5.25"
Polypropylene cone
Rubber surround
Cast Frame - truncated
Ventilated raised spider
Shorting rings
152mm flange
134mm truncated
120mm cut out
61.5mm depth
Znom 8 ohm
Re 5.7 ohm
Le 0.6 mH
fs 56.1 Hz
Qms 2.41
Qes 0.50
Qts 0.41
Mms 8.1 g
Cms 0.99 mm/N
Sd 88 cm2
BL 5.7 N/A
Vas 10.6 ltrs
Xmax 3.5 mm peak
Voice Coil Ø 26 mm
Sensitivity
2.83V / 1m 88.3 dB
Power (IEC) W
Magnet weight 0.4 kg
Suggested box alignments:
Sealed box of 5.5 liters (0.2cf); F3 of 95Hz
Vented box of 8 liters (0.28cf); F3 of 60Hz; 1.5" vent by 4.25" long
Seas Excel W12Cy-001
$175 4.5"
http://www.madisound.com/catalog/product_i...products_id=780
utside diameter 120.4mm
Cut out 95.8mm
Depth 58.5mm
Nominal Impedance 8 Ohms
Recom. frequency range 60-3500 Hz
Short term max. power 200 W
Long term max. power 70 W
Sensitivity (1W/1m) 85 dB
Voice Coil Diameter 26 mm
Voice coil height 12 mm
Air gap height 6.0 mm
Linear coil travel (p-p) 6.0 mm
Max. coil travel (p-p) 9 mm
Magnet weight 0.42 Kg
Total weight 1.21 Kg
Voice coil resistance 5.6 Ohms
Voice coil inductance 0.3 mH
Force factor 5.6 N/A
Free air resonance 46 Hz
Moving mass 7.0 g
Suspension compliance 1.7 mm/N
Suspension mech. resistance 1.0 Ns/m
Effective piston area 50 sq. cm
Vas 5.8 Liters
Qms 2.2
Qes 0.37
