Full Version: 8" midbass into pulsar door
keepitreal07
hello everyone. i need some help.
I am upgrading my midbass to a peerless sls8"
The problem i have is that i need 24 mm spacer of the door skin to clear the magnet.
That easy..................Not!!!
You can see from the pics that it goes back on the top left section. (10oclock)
If i bolt a spacer onto the steal there is a gap in this section.
What can i do, am i able to glass a bass and then just like leg the spacer thing onto it
daniel`
If there is a space, just jam some closed cell foam in there..
Woob
expanding foam
keepitreal07
stickerflex
Use one large piece of f**k off MDF to cover the entire door. Seperate the back and front waves to prevent cancellation, use a strong baffle to load off, and you can attach any additional spacers needed onto that.
Add to that, you can get creative (like your new dash piece...) and add door handles, window winders, locks etc. on to that, and have a fully functioning door.
Luke352
Moddeling clay works well to seal any gaps you may have, otherwise forget the door and build enclosure's into your foot well area, for a rise of 6-7cm in floor level you can get from 10-20litres depending on the car.
Woob
keepitreal07
mmm.....luke...sounds like fun......but i not think my car will suit midbass in the floor.....mainly cause of the limited space.
also this is the specs from madisound
Box suggestions:
1 to 1.5 cubic feet sealed for F3 of 47Hz
1.6 cubic feet with 3" vent by 6.75" long
F3 of 33Hz, with +2dB bump
1.5cf is 42ltr no way will i get that in the floor let alone the door....ill do my best though....
i not sure if this will suit....damm i got a pain of a car.....why did i choose to do this myself:)
zion187reigneth
bracing the woofer mounts to the outer panal and surrounding area is the go, Doors dont like low bass hits, u get huge amounts of energy and deadning can only do so much.Your bracing technique should be a disipation setup i reakon.
keepitreal07
you mean outta panel as the one that is on the outside of the car. how will i do that...window comes past the magnet......i wont be able to do it right.....i could prob make a ring that bolts onto the door......glass the holes....then glass a pod onto it.....then make the door trim to suite:)
keepitreal07
will liquid nails work
TripleXTX3
make to fibreglass pod/pocket on outer door skin?
smooth out and paint or vinyl it.
keepitreal07
not enought room......i have the spacers attached to the door n using the door as enclosure
TripleXTX3
could u not make the door trim slide over a pod spacer for your extra clearance?
keepitreal07
thats wat i doin if we both on the same page
here are 2 photos that show wat ill do
TripleXTX3
nice.
are your going to build on the trim to surround for the spacers?
keepitreal07
exactly....i think it will be easier to mould it over the front
TripleXTX3
cant wait to see how it comes out mate....
oh u gotta let me hav a listen at the next meet....
jukebox
just adding some fuel to the fire mate, but i once saw a guy mount his midbass 8s in sealed boxes in front of the seats pointing up at the window, the car was an award winning vehicle not a slapper, it had a fair amount of custom work done, mainly a modifed fire wall to allow for the factory position of the 4inch mid ranges to take a 6.5 inch driver and enclosure, ill try find the article and read up on it, it was a few years back, and who knows what he was using to get a good tune on this set up. but yeah, award winner so it had to sound ok,true? what do you guys think of that idea and does any one remember the car.....ca&e about 5 yrs ago...
keepitreal07
IH8SQ has dyn 9" in boxes in the floor...they sound good..
but my car is a daily and it would be a pain to put them there....
jukebox
yeah, it has to be user friendly hey, you could get a decent sealed box there tho, if you used the area under the seat and then flared it out to the ring shape, you'd get a big enclosure actually, and would only need to have the actual speaker size out in the open in front of the seat, not a whole enclosure, just some feed back mate, good luck
Damo95
i also know that PYROAY & cyberpunky had floor mounted midbass's....
bruce's were boxes above the floor, in front of the seats..
while Aaron's were fully moulded boxes into the floor and sat flush..
jukebox
yeah its definately an option hey, that Aaron is another mad man like you damo, always changing around,lol....ive seen his car in a few diffrent stages and yeah the mids flush mounted in the floor made me look twice...
veiwed ur vs install last night, all 20+ pages,lol...your crazy man..hehe..
so what do you think of the underseat box, you can wak your speakers there too see how intrusive they will be but i think they would be ok, you could go as far back with the enclosure as the rear seats foot area, itll just be like a raised floor in there, could get an easy 10ltrs doing it that way, just sharing some ideas mate, if your positive on the doors, im not sure how you would get them in and looking neat....
TripleXTX3
any updates brother????
keepitreal07
um.....i have looked into floor midbass but not wanna as i not gunna have alot of room because of the midrange..
ill take some dimentions/photos soon.....but i have already cut up my door panel so wanna really leave em in the door....
keepitreal07
here you go TripleXTX3
I got a little busy this arvo.
i will get the general shape with strech material and the bog etc to get finished shape.
then use it as a mould and make a carbon fiber one
TripleXTX3
looking good buddy....
keep workin on it!!!!
keepitreal07
it looks ok....but stuck to the door frame and when i pulled it off......aint wanna move.....must now rethink how to do it....
TripleXTX3
i know u told me today wat uve done but i want pics!!!!
plus i'm sure other do to!!!
muzzy66
For what it's worth, you the SLS should (theoretically) work well in 26L if filled heavilly with dacron.
It doesn't work in every scenario, but based on the way it modells out, I think it will work here.
Whether you have 26L available is another story though...
super_sheep12345
keepitreal07
yea:(
some cheap thing from bunngings.....i have changed my approch.....when i get catalist ill re do it
keepitreal07
i have just found this...might give it a try
TripleXTX3
update????
KIRBO
Thats a good idea Matt. Hope your material choice is a lil better though. smile.gif
Have you considered recessing the woofer? IMO its a better look.
keepitreal07
Kirbo: yea i did think about it but my fabrication skill aint as good yet to do it. also i dont have to jig to put onto bottom of router yet to do it......
TripleXTX3: there is no update becasue i not do it yet....tryin to do the boot atm and i only have 1kg of resin left
TripleXTX3
dropped off the first page....
updates bro????
keepitreal07
no updates yet mate....
i will do it that same as above pic when funds allow
