QUOTE (Juls @ Aug 7 2008, 04:38 AM)
I wouldn't pay too much attention to what muzzy says, he's looking at charts and computer software.. he doesn't own the speakers.. so it's still guessing based on techincal data.. which seldom shows the whole picture. and rarely allows for cabin gain.
Question:
How much effect will cabin gain help a speaker that is 3dB down by the time it reaches 80hz?
Think about that one, and get back to me.
I tried running the TN52 to the 100KP active for a long time,
but never managed to get them to sound as nice as when you just use the supplied crossover.
Maybe you could have, if you tried my recommended settings
(joke)
in the end I ended up running the 100kp with the TN52 on it's own x/over at about -5db setting on the x/over roughly. (stock x/over is 3.5khz 12db, this works perfectly fine)
Funny, that sounds surprisingly similar to the crossover point that I recommended based on my 'charts'.
What an amazing coincidence!
the KBE/K3p Driver I run at LP 280hz 24db, and High pass at 63HZ 12db (the KBE can handle MASSES of power at that crossover and placed low in the doors still happily pumps out frequencys in the 50hz region even with that crossover point)
Yes, it can
handle power at 63hz...however it won't
produce good output at 63hz.
At around 100hz those midbass drivers will already begin to roll-off, resulting in a gap of some degree between midbass and sub if you cross lower then this.
I'm famillar with the 6K2P not only specs-wise, but also in person - I did a lot of back to back listening with those speakers against a good degree of other high end ones in a well controlled environment. Indeed, they produce better midbass then any other component set I've head, but they are still only effectively usable down to 80hz
at the most. Even at an 80hz crossover point, there is a noticable gap in between it and the sub. The bottom end output doesn't vary that much between the K2P and K3P driver...the K3P has
slghtly more extension, but it's not by as much as most people seem to think.
You think just because you can 'hear' 50hz frequencies coming out of the mids, that it means they are good to be run that low? Contrary to what you may think, either of those drivers will be down by at least 3dB by the time you get to 70hz - at 60hz they will most likely be about 4.5dB down or so (rough guess) and by 40hz-50hz your're absolutely wasting your time because half of your low frequency information is lost.
every car is different so the x/over points you will need will vary somewhat.
The car doesn't determine your suitable crossover points...the placement/install/angle of the drivers determines suitable crossover points. Angles of mids determine where they will roll-off, and hence where you should cross them over (as you want to cross them to play within their effective range).
Put the same mids at the same angle in different cars, and the recommended crossover point will be the same.
Don't be scared to run a 12db 60-80hz cut on your KBE. Most speakers will die a
painful death with any power applied to them with those types of crossover,
but the KBE handles it with ease. doesn't break a sweat even in the toughest goings on.
Why?
That's lilke saying "don't be afraid to run a 12db, 2khz cut on your TN52s".
Sure they'll handle it, but you'd be wasting your time because the output below 80hz will be too low to be of any use...
Running a 100hz 24db high pass cut on the kbe is nothing more than a joke. And simply
ruins this excellent midbass driver.
If you are going to make such a blatant statement, then at least offer
some form of justification.
Let me put it simply for you:
* The Focal midbasses
will begin to roll off at 100hz at least (if not earlier) no matter what enclosure they are or are not in (unless if it's vented).
* If you cross your sub over at 80hz, you will have some degree of gap (degree depending on how far down it is) between your midbass and your sub.
* Gaps in response sound bad - you will miss out on musical information below 100hz unless you 'band aid' it by using a shallow slope, in which case youll cover the gap and muddy up your sound in the process.
All of this is ASSUMING that you are running that midbass in an enclosure designed for the best possible bottom end extension - which car doors are NOT.
Not sure if you recall, but one member on this site actually ran his K2P drivers in his doors, and then ranthem a second time running in door mounted enclosures. He took physical measurements of both cases, and not only did the 'door' mounted install result in nasty midbass resonances, it also resulted
extreme roll-off below 120hz to the point where below 80hz the output of the speakers' was all but useless. By comparison when he mounted them in the doors the resonance was gone, and the extended FAR lower.
In fact guess what - I just remembered I actually saved the graph he posted at the time (with his permission), so here it is (my apologies for not properly crediting him, as I forgot his username ("powerband" or "powervan" ring a bell, but not sure).
Take a look at the response of the 6K2P's in doors, and then tell me if you still recommend running them below 100hz...
And this are not 'charts and computer software' it's actually real world measurements that the person took of his system.
As you can see, the K2P mid was actually a full 10dB down at 80hz when mounted inside the doors (3dB down when in enclosures). I personally
guarantee you that a simple 1mm or so increase of xmax (that the KBE has over the K2P) will
not translate into 10dB more output at 80hz then the K2P...however it would have to produce AT LEAST 7dB more output at 80hz to make it even
remotely useful at that crossover point.
Also, notice that the measurements taken of the K2P's bottom end
in the enclosure pretty much perfectly matched my earlier predictions (which were a roll-off beginning at 100hz, 3dB down at 80hz and 4.5dB down at 60hz).
Surprised? I'm not!
But hey, "pay no attention at all to what muzzy says, as he's just just looking at charts and computer software".
