Firstly, my left and right channels are correct and are in Stereo for both the mids and tweeters
secondly my headunit I have to adjust the time alignment values manually (W200 + H701)
from the alpine manual, the furthest speaker - current speaker
then divide by speed of sound and x 1000 to get the delay on each driver
first question... would this formula apply to all speakers? as tweeters play higher frequency, so would that mean i'd have to take that into account with the distance between me and the speaker? i.e would the sound travel faster in some way? as its a high frequency?
2nd question
when i sit in the passenger seat, I have adjusted the speakers by the above formula, and the sound appears to come from the front of the dash on the passenger side which is great
problem is... on the drivers side, I have done exactly the same, as the above method, and the sound seems to be dragged to the left of the car?
yet i measured the distances and followed the above procedures
So have reversed these numbers and tweaked them by ear, which now results in the sound directly coming from above the steering wheel area which im satisfied with.
what would cause this? does the steering wheel and/or other objects effect the actual distance, reflections?
And if it was a phase issue, I would have the same problem in the passenger seat?
Have seen Timm3hs thread too, and it is an interesting read.
