I've deadened my doors with dynamat extreme and during normal listening there is minimal resonance but at higher volume I can feel vibrations when I lightly touch the door trims.
I thought that wasn't a bad result because I'm running 8s in the doors.
I was listening to the sine sweep on Highway One today and at two points during the low frequencies there was a distinct vibration of a higher pitch than the tone maybe at about 100hz and 200hz.
This is more noticeable in the driver's door and I think this is because the resonance causes the door mounted power window console to vibrate at a higher frequency.
How effective is adding a second layer of dynamat to the inside doorskin?
What is the best product to apply to the inside if the door trims to reduce the resonance?
The trims are made of compressed fibres similar to mdf.
I've been told dynamat doesn't stick to this stuff so well.
Would Sound-off be the best stuff?
I'm a bit doubtful because it is light weight.
I've always thought adding weight was an important factor for deadening.
