Hi Guys,
Well rather then add to my bloated RTA thread, I thought I'd post some data here that I recorded tonight from the Aura NS3's.
My first impressions of the speakers are wow, they are so cute. Like a really little midbass/sub.
Click to view attachment
The driver is classified as a 3inch extended/fullrange driver, specs can be found here...
http://www.madisound.com/catalog/PDF/auras.../NS3-193-8A.pdf
Aluminum cone
Underhung voice coil
NRT neodymium magnet system
Inherently shielded
Rubber surround
Specs :-
Fs 80 Hz
Nominal Imp. 8 ohms
Power (RMS) 20 W
Re 7.6 ohms
Sens. 1W/1m 80 dB
X-max peak 3.1 mm
Qms 8.0
Qes 0.73
Qts 0.67
Vas 1.25 ltrs
BL 4.7 TM
Mms 4.3 gr
Cms 920 mM/N
Sd 31 cm2
Net weight 216 g
Max Exc. p2p 20 mm
VC diameter 19.3 mm
I ran some sweeps and tested in ARTA via the soundcard output and through a small Coustic AMP 207 amplifier.
The response curves don't look too bad at all Almost flat from 100hz up to 2khz where it jumps up to about 5/6dB increase in level. This is different to the provided response from Aura in the above PDF hoewever, which shows fairly smooth to 6khz. I've included a plot of each driver measured seperately but superimposed. The Mic was placed 5mm proud of the rubber surround of the driver in the centre of the cone in order to reduce environment impact on the results. Drivers were free air sitting on the table.
I've also included a plot of the amplifier output measured with ARTA also, to see if for some reason the sounds card was adding to the response curve, but it seems fairly flat also, bar the peak in the low freq and some mess after 20khz.
I'm potentially looking to run the drivers as the midrange sitting on the dash, either on axis to the listener, or firing into the screen as my tweeters are currently. I have access to a AC EQL and a 2-way active crossover that can crossover anywhere up from 640hz to 10khz so have a bit of flexibility in respect to crossover points. Unfortunately they are fixed at 12dB slopes however.
Some rough testing moving the mic around the driver showed the off axis reponse to vary in the lower end more so then the upper end, but this won't be a true indicatino as the drivers were tested in 'free air'.
