Recently installed a Pioneer GM7300 amp into a 2008 Mitsubishi Lancer and have had lots of problems. All wires are fine, amp has power and a good ground - running high-level inputs from the rear speakers. The amp was running a single 12", now running two 12"s and has the same issues. No music coming from the subs, but a 'pulse' every few seconds, regardless of whether the amp has an input. The amp worked fine when it was installed, came back a few days later in this state. Sent the amp away for warranty, installed same model amp and it was all fine. Three days later, the car comes back in with the same issues.
Any idea's what the problem might be? All I can guess is the factory headunit has too high of a signal running to the high-level inputs, and it's frying something in the amp.
