dardywgn
Jul 27 2008, 10:09 PM
Head unit
Splits
Subs
Amps
hit me up with anything you have to offer
keepitreal07
Jul 28 2008, 08:33 AM
mtx 50x4.....dont remember the model
bozman8
Jul 29 2008, 02:17 PM
Fusion Powerplant 12" Sub? About 350/400WRMS, 1 year old, no box(will have to post from Townsville)
Big Kev
Aug 10 2008, 01:33 PM
WA - (x2) Alpine – V12 2 Channel Amplifier – MRV-T420
RRP $699 – discontinued in mid to end 07 with the release of the new V power series range.
Power Output:
RMS Continuous Power (at 12.0V, 20 Hz to 20kHz)
Per channel into 4 ohms (0.08% THD)
75Wx2
Per channel into 2 ohms (0.3% THD)
120Wx2
Bridged into 4 ohms (0.3% THD)
240Wx1
Power Output:
RMS Continuous Power (at 14.4V, 20 Hz to 20kHz)
110Wx2
170Wx2
340Wx1
Total Max.
600W
Frequency Response
10 Hz to 50 kHz (+0, –1 dB)
Signal-to-Noise Ratio(referenced to rated power)
100 dBA
Slew factor Greater than 5
Input Sensitivity (for rated power Output)
200mV to 4.0V (1.0V at center detent)
Input Impedance
Line in: 10k ohms < Speaker in: 15 ohms
Speaker Impedance
4 or 2 ohms (Stereo), 4 ohms (Bridged)
Active Dividing Network Frequency and Slope
15 to 400 Hz, 12 dB per octave
Power Requirement
11 – 16V DC Negative Ground
Dimensions (W x H x D)
315mm x 68mm x 247mm (12-3/8" x 2-11/16" x 9-11/16")
Weight
4.0 kg (8 lbs. 13 oz)
Have 2x of these for sale both work beautifully and have only been replaced due to going for more powerful gear. These were both used to run my rear shelf.
The 1st is in almost perfect nick with only a tiny mark here and there the second has a couple scratches and chips just from my install being ripped in and out so many times....the main reason for the $50 difference is there is a small peice of plastic that holds the leg in for the covers hinge...on one side this is broken and the hinge is missing...the cover stays shut just rattles with vibration....could be fixed with a small hinge quite easily just never got round too it.
Asking $300 + p&h for the one in better condition and $250 + p&h for the second.
Shoot me a pm if interested - can email pics if required
Cheers Kev
DanYboi
Aug 20 2008, 08:55 PM
hey mate i have the following
2x Crossfire P1 subwoofers ( used)
1x phoenix gold X12d4 subwoofer ( new)
1 set rainbow SLX-265 splits (new)
1 set focal K2P splits ( new)
1 set pioneer 6x9
let me know if you are interested in any
I also have a head unit, used in mint condition
Pioneer DEH-5750
$150
dardywgn
Aug 23 2008, 07:47 PM
how much are the rainbow and focal splits?
QUOTE (DanYboi @ Aug 20 2008, 08:55 PM)
1 set pioneer 6x9
Pioneer DEH-5750
$150
