QUOTE (~thematt~ @ Aug 13 2008, 11:52 AM)
The Hafler is passive, yes. I'm not sure i fully understand your question though?
You need to ensure (either via a bridge switch, or simply using a DMM) that both channels of the stereo amp are in phase with each other. Then you simply hook up the positive channels to the positives of the speakers, and the negative coil of the speakers to each other.
Then add T/A.
What I meant was:
The hafler circuit I googled ran fronts and rears off two channels.
Will it still work properly if I hook the rears up this way to two channels by themselves?
But i think you just confirmed it will.
The problem is I don't have time alignment in my current setup.
I'm not sure I can justify buying a pxa h701
How much delay would be available if I update my eclipse hu to a cd7200 mk11 which I was considering anyway?
Do you think a pot between the speaker neg and amp neg to adjust the balance between difference and full signal would work in a car?
