Full Version: small things to maximis sq
Shreknos
hi guys this thread is not only to help me, but im hoping it will become a genuine go to guide for small cheap ways to maximise sq,
im going to run through some small things iv learned or heard of along the way, with hopes that some of the super nerd sq nutts can describe the reasons and effects while adding tips of there own...
- the big three, earthing through engine bay to engine, from alternator to battery, and from chassis to bettery
- running positive AND negative power cables from the battery to the amps, to avoid any noise problems, and maximise power delivery
- use sufficient size speaker cabling for speakers, spesh subs and mibass'
- use qulity built rugged RCA's
- sound deaden floor and kick panel area for road noise rejection
- sound deaden firewall for engine noise rejection
- brace door cavities properly when employing high impact midbass', not just sound deaden
- cover the bottom of the dash and any under dash exposed areas to stop notch filtering and resonances or something - supposed to be important, tho i dont no why exactly
- ensure both sides of the front stage are mirror images for equal freq responce, angles heights etc
- instead of tuning for a perfect flat responce, try for equal responces from both sides as priority
- allow head room for dynamic transients while chosing amps, and allow more power then needed
- keep gains down for reduced noise floor
- cover any feesable surfaces with foam or absorbtive material such as dashmatts etc
- make sub enclosures as solid as possible to stop resonance and loss due to weakness, through bracing
- have solid baffles for all speakers
- dont cover speakers with door trims ect
again, very brief, but important things that most sq noobs may not know,
please feel free to throw in your own, as ill be starting my own install soon, and am looking to maximise a simple stereo for once instead of having a expensive complex stereo running low on efficiency...
thank you
shrek
Alternator to battery shouldn't be necessary unless you run a lot of power, often. i.e. >2kW RMS worth of amplifiers. This is simple physics, at 'normal listening levels, you're only drawing a maximum of 30A continuous with the stereo. as long as the factory wiring is done properly, the factory earthing of the alternator should be more than adequate. Of course for the small amount extra, you can do it if you want.
Definitely 'upgrade' the factory battery wiring to chassis and engine. Other additions are inlet manifold, head and gearbox/transmission. Remeber to properly clean all paint and oil away from the connections prior to bolting them up.
Once again, it really depends on your system power. The chassis/body has enough metal in it to happily supply over 4000W continuous power to your car audio system, even if it's in the back of a commo wagon. Use the 'baby seat' bolt holes as earthing points - they have plenty of metal around them due to reinforcing requirements. Up the front, or right down the back, the bumper bar bolts are a good point to get a chassis connection. you need at least the equivalent of 2x 0ga copper to get better circuit than the chassis from the back to the front of the car.
From experience, I recommend a minimum of 14ga for up to 500W RMS, and bigger for more... 8ga is plenty for 3000W RMS power to the speakers.
excellent!
also deadening the roof helps to reduce traffic noise, and gives the whole car a more solid 'feel'
not as important I think, as most of the 'problems' in car audio reproduction are associated with the foot well, console and shape of the dashboard and windscreen. If you've got nothing else to do, then try it out.
the biggest hindrance to this important point is the steering wheel, and the fact that very few modern cars are symmetrical in the front area.
definitely! A smooth response is more important than a flat response, and even as little as 0.5dB difference from left to right can be audible in a critically tuned system.
not the cheapest advice, but certainly good to note. Also to note is that all amps aren't created equal, and some amps will only deliver high power into low impedance (ohms) load.. A good amplifier should be able to deliver its rated power into 4 ohms, at 12V supply (or lower), and with less than 0.1% distortion. any amp that lists a 'peak power' should be avoided.
any decent amp will not have noise - even with the gains wound flat out.
In general, this is a good idea, although some reflected sound can have a positive effect on the SQ - such as stage width and height. The biggest reflector in the car is the windscreen, and you can't really cover that with padding. Also to note is that 'overuse' of padding, etc, will make the car sound too 'dead' - there should be some ambience in the sound.
I totally agree!
Damon
My first submission:
If you want a speaker to sound like it is coming from somewhere - put it there!
In other words, no amount of time correction, angling or other trickery can truly fool you into thinking a speakers is somewhere it is not.
Second submission:
Sub bass IS directional!
In other words, sure, with a constant sub 80Hz tone you'll have a hard time discerning the point source of a subwoofer, but music does not work like that. To prove this, simply replace your boot mounted subwoofer a small subwoofer in the passenger's foot well running from the same amplifier and crossover. You'll note immediately that the bass is now up front. - see submission one.
br85
QUOTE (Damon @ Aug 6 2008, 07:49 AM) *
Certain playback methods are supposed to do exactly that! Stereo can (but we cannot achieve stereo in a car), ambiophonics can (we can achieve it in a car, but i'll be stuffed if i'm gonna rip up my dash to try it), mono can (but I think mono makes modern music with no natural revereb sound "dead").
But in essence, you're right. out of the millions of people with car stereos, probably only a small handful have achieved a sound where the speakers cannot be located by ear.
Second submission:
This is not entirely accurate, it is not the sub frequencies that are locatable, it is the resonances in your car. anything below ~350hz is not locatable by ear. What your brain is doing is hearing that the resonance (higher order harmonics btw, above 350hz) from "panel X" or "seat y" or "whatever z" is louder than some other resonance, and your brain locates the sub at the point where the panel vibration is strongest. This doesn't mean you deadened you car poorly, it would take INCREDIBLE amounts of deadenin to fully hide a sub's location, but I assure you that sub bass itself is not directional.
Getting the time, phase and polarity of the sub correct in relation to the midbass is the key to 'up-front' sub bass. Of course, the best way to solve this problem is by putting the speaker in front of you.
QUOTE (br85 @ Aug 6 2008, 09:57 AM) *
I have to disagree here on a technical point.
The ears are sensitive to phase differences up to about 1kHz (ref: Rumsey, F., Orchestrating Automotive Audio, J. Audio Eng. Soc., Vol. 56, No. 4, 2008 April).
From the midbass and subbass at the crossover frequency, the difference in arrival time, or phase, of the lower frequencies is what determines the 'apparent source' of the subwoofer
Resonances are important cues, and the only resonances should come from the music. i.e. if the sub is playing 40Hz on a double bass, then there will be natural harmonics at 80, 120, 160, 200 Hz... and beyond. If the peaks and troughs of the subbass is not aligned correctly in time with the midbass, then you will hear that the sub is not in front of you with the other speakers. You need to have all the speakers aligned acoustically to get true imaging across the audio spectrum.
If you can replace 'Sound deaden' with 'Acoustically treat', I would very much appreciate it. I just dont have the energy at the moment to drum up my speech on why Sound Deadener is such a waste of money when using to eliminate road noise, but just note that it pretty much is.
As to Damon's comment on localizable subbass, I agree. I'll add to that though that ALL speakers NEVER just play the information fed to it. If you send 20-80Hz to your sub, your sub will still play (audibly) tones right up to ~300hertz. Its called harmonic distortion, and is very localisable (especially when combined with resonance).
There is a study out there, cant remember the name, that actually demonstrates frequencies down to around 100Hz can be localizable too. Might have to dig that up.
This is the only one I disagree with:
This simply is not true. Proper Stereo reproduction does this, and does it well. Its called Phantom Center, and its what we try to aim for in our cars (albeit we fail..)
Keep in mind the ultimate aim is to remove the speaker from the reproduction altogether, so you never know where it is (audibly).
Shreknos
please do take the time if you dont mind Matt to expand on ur statement on sound deadener, and alternatives i may employ before i order mountains of it...
cheers charlie
Damon
Oh no, can open, worms spilling out everywhere...
LOL
Regardless, my own personal experience in all the cars I've built has left me with the opinion that placing a speaker where you want it to sound like its coming from is the first step of getting things right - hence it fits the theme of this thread's original purpose.
QUOTE (Damon @ Aug 6 2008, 04:37 PM) *
LOL
I can full understand the intent of this statement, but I still disagree. Here's why. Anyone who asks where should they mount their speakers, doesnt have the knowledge to pull off kick panel installs, so you'll never get proper height, hence with that, I agree.
However, I dont think its practical to put a center channel in the middle of my bonnet, and a left/right channel both around 3-4 foot outside the boundaries of my vehicle. Thus my disagreement. I put the speakers where they should go, and utilise physics with driver/enclosure/environmental interactions to give me what I need.
QUOTE (Shreknos @ Aug 6 2008, 03:49 PM) *
cheers charlie
Just a quick one Charlie, 'cause god only knows most people will skim over it when its too long!! (I've typed it up before, so a quick search will give you more details).
Sound deadener is a Mass Loaded material that is purely designed to move the resonant frequency of the structure it is attached to, in order to limit sympathetic vibrations (resonance). Add that mass with anything (including wet sponges, or dirty laundry) to the same structure, and you will achieve the same result. Sound Deadener, like Dynamat, is fit-for-task in that it is well designed for the Car environment (heat, longevity, sticky backing...), but you need to remember, that task is damping vibrations, not acting as an acoustic barrier.
If you want to lower outside noise inside, you need to employ different methods. One is to block the incoming sound, the other is to absorb it. Sound Deadener is useless as both. Jump onto google and look up 'Acoustic Absorption Coefficient' to get a list of materials that absorb well. Type in "Acoustic Reflection Coefficient" to find materials that reflect well. Using a combination of both will benefit you the most. Just remember to seperate the material from your car chassis (using something like foam) in order to prevent vibration transfer through the medium (which will negate its effectiveness).
In Sound Deadener's, the ONLY part of the material that actually attempts to limit the incoming sound is the aluminium backing, and thats only a few mil (thou' inches) thick. Want to do better for cheaper? Buy 1mm thick aluminium, and put it in your car. Costs a fraction of the amount.
Sure if you put 8 layers of deadener on there, it will be effective. But its about as effective (and costly) as putting 1000 tweeters in your boot to recreate subbass. Right tool for the job, first time. Personally, I'm going to be adding Lead throughout my vehicle. And I aint paying more then $200-odd dollars for it.
Luke352
QUOTE (~thematt~ @ Aug 7 2008, 10:48 AM) *
Some previously found links for those lazy people.
http://www.signal-processing.com/tech/us_data_solid.htm
http://interactivesonicspaces.interfaculty.../reflection.htm
2LOUD2OLD
shok.gif lead, me thinks your car is going to be rather heavy
Car's are for stereos.
I spent 90% of my time listening in the driveway. Plus, fuel is expensive.
br85
QUOTE (~thematt~ @ Aug 7 2008, 11:05 PM) *
One must ask, then, why you would bother to use all that lead to block out road noise when 90% of the time, you won't have it? unsure.gif tongue.gif
br85
QUOTE (Pulse-R @ Aug 6 2008, 10:29 AM) *
I understand exactly what is being said, and the point I made was that sub bass is not directional. Harmonics are, yes, resonances are, yes. I simply stated that sub bass is not directional. Maybe I shouldn't have said so since in a car, we DO have all the other factors to think about, and so we have:
"sound coming out of our subwoofers" is locatable.
"subbass itself (<100hz)" is not locatable.
also, properly implemented rear channels (20ms delay, bandlimited, Hacked up L-R, mono, ambio signal) or center channels WILL make a soundstage much wider than actual mounting positions allow. Much more so than time alignment can. Actually, I tend to find that the more focussed my phantom center is, the more narrow my staging seems using only L/R time alignment.
muzzy66
QUOTE (~thematt~ @ Aug 7 2008, 01:05 PM) *
Damon
QUOTE (~thematt~ @ Aug 7 2008, 12:48 AM) *
This is not what I meant Matt.
I think I get what you mean, because you're referring to height yeah? Simply put tweeters up high if you want good soundstage height?
OK on the subbass being non-directional in those terms.
I have my sub crossed over @ 140Hz , it seems ok.
zion187reigneth
hello shrekno, i think u have touched on a good point with under dash design ,its the only part of my car i havent had a go at and i was getting bored ,cheers
Shreknos
zion,
how are ya bro, hope ur cars kicking arse, well hook up soon so u can hear my new creation, will be done right this time i promise,
any tips to add in all ur adventures??? ur definitely one of the pioneers of non conventional installation techniques!!!
zion187reigneth
yes, run test tones 15hz and up in 1 db increasements and record on paper and then locate individual rattles and fix. eg~ rattles and hums appear at 68hz but not at 67 or 69hz.
Keep doing it till your car it rattle free.You may have to think up ways to solve your dramas.
Test your woofers seperately and together, so it may take a while to truly do a pro job.
QUOTE (Damon @ Aug 6 2008, 08:37 AM) *
...in all the cars I've built ...
Im sure thats in the thousand's lol
anyway
I have had so many ppl jump in my car, listen and say "I cant believe you get 8s to get that low" etc. I say to them look behind you and they see Im running 12 inch subs as well, yet they hear the bass up front. Go figure. But then I get told by so called experts my stage must be low as my speakers are mounted in kicks.
I have had one industry figure ask me where he can get some of these windscreen speakers lol, but he just listened with his ears.
As stated you cant hear the direction of sub bass period. You can hear resonances and harmonics. I'd suggest you learn your craft then give advice, but thats just me.
I am not a fan of using TA when a decent install works better but TA works (at least from one seat unless you really know what your doing). Im also not a fan of self impossed god syndrome but thats another story lol
syd-monster
QUOTE (Original Warrior @ Aug 5 2008, 10:23 PM) *
thank you
shrek
To add to this insightfull thread. My 2c advice.
- Choose to purchase quality equipment the first time. It is generally a better option to buy a decent single component, than a lot of cheap gear (for the same given price). Quality gear can be built up on later as needs change.
- When mounting drivers, a solid/rigid surface is better than a surface that has give. That is; think about how will the driver (speaker which is shaking forth & back with the music) affect what you are mounting it to? How much will it move with the speaker? Is there a better location for it? Can you stiffen the surface first? Do not confuse this with deadning or noise reduction. Look at it purely from a mechanical point of view.
- Learn your music. Get a referance, a good starting point. Home Hi-Fi's make a great reference to compare your car's system to. Use a quality disc, close you eyes, pay attention and see if you can spot the differences and where one is better (to YOUR EARS) than the other.
- Big Bass is not Sound Quality... if your bass overpowers the rest of your system then it migth "pound bass"; but what about the rest of the music?
