The latest offerings from Danish loudspeaker manufacturer Dynaudio are the Esotar2 range of high end car audio component speakers.
Tweeter Esotar² 110
Dynaudio has established a reputation of producing some of the best high frequency drivers available with its Esotar Home Systems models, incorporating its most refined technology into new reference automotive tweeter – and bestowing such with the Esotar designation.
The new Esotar automotive tweeter features a specially coated 28 mm (1.1") diameter fabric dome, a powerful neodymium magnet and an exceptional CNC-machined metal housing with a damping back chamber.
· Coated textile dome eliminates any high frequency break-ups
· Very strong neodymium magnet system with vented pole piece
· Open, spacious and detailed high frequency reproduction
· Excellent dynamic and transient performance
· Integrated damped cavity chamber in the pole piece
· Variovent integrated in back plate
· Ferrofluid adds damping and increases power handling
· Aluminium voice coil wire results in a low moving mass
· Shallow mounting depth
RRP A$1699.00pr
Click to view attachment
Woofer Esotar² 650
The 17 cm (6.5") diameter Esotar midrange/bass driver relies on the rigid, die-cast solid aluminum frame and Dynaudio's characteristic MSP (Magnesium Silicate Polymer) diaphragm.
The voice coil diameter is exceptionally large at 75 mm, but by using extremely light aluminum wire wound on a Kapton former, the coil remains extremely lightweight. In conjunction with the powerful neodymium magnet, this low-mass driver construction provides excellent transient response, speed and precision.
· Diaphragm and dust cap moulded as one piece
· Large 75 mm voice coil ensures high power handling
· Internal double magnet system with vented pole piece
· Internal double magnetsystem with neodymium magnet and vented pole piece
· Aluminium voice coil wire provides for a low moving mass, wound on kapton former in a car
· Rigid die-cast chassis with aerodynamically shaped ribs
· Materials and parameters are optimized for the harsh environmental conditions in a car
· Smooth high-frequency roll-off
· Natural midrange reproduction
RRP A$1099.00 pr
Subwoofer Esotar² 1200
The Esotar Subwoofer also features a unique construction:
A massive magnet powers a 75 mm diameter aluminum voice coil and MSP cone diaphragm.
MSP provides the ideal combination of stiffness, light weight and excellent inner damping to naturally reproduce the lowest frequencies without distortion.
Thanks to the innovative Dynaudio construction with precise parameters and extremely tight tolerances, this 30 cm (12") diameter driver reproduces the highest sound pressure levels down to the lowest notes by precisely following the amplifier's signal, even at the highest output levels.
· Diaphragm with very high excursion, 58mm peak-to-peak
· High power handling, 400W long term IEC
RRP A$1599.00 ea
The full Esotar² range is available in Australia now. See you local Dynaudio dealer or contact Mobile Audio Solutions for more information.
