QUOTE (Hissey @ Aug 12 2008, 10:45 PM)
the only real benefit from having the box divided is that if one sub dies the other will effectively be working in an enclosure twice the size, but if both subs are working fine then there is no advantage, apart from extra bracing, but as SPL lancer said, if its built well, then no problems at all
And if one sub DOES die you can just use the old trick of temporarily reducing the internal volume of the box down to what's appropriate by using old magazines and/or books taped together (to the total volume you want to reduce the box by) and secure them inside the box. Then rip the motor assembly off the dead woofer and use the cone/basket assembly as a passive radiator until you get a new sub. hehe
I've seen this done more than once.
