Hey guys,
Okay so a quick run down. I have a VY Commodore. I recently finished installing my stereo. I kept the stock Blaupunkt Headunit. I am running Hifonix splits in the front and alpine two ways in the rear doors.
Under the parcel tray in my boot i mounted a piece of timber to then mount my two amplifiers two. Both of my amplifiers are response jay car branded amps. One is a 4 x 100wrms for my speakers. The other is their digital monoblock which puts out 300wrms @ 4ohms. The monoblock is running a 15inch Cadence Sub in my boot.
Since i finished the installation I have been having a problem with my mono block amp cutting out and going into protection mode and i dont know why.
My first two thoughts were it to be either a power or heat problem. I recently tried to elimiate the option of power being a problem by installing a 1 farad capacitor in my system. I noticed a change in the sound quality with the better power supply. However, am still having the problem with my amp.
I am desperate for ideas guys so if you could throw yours my way i would really appreciate it.
In terms of cabling I used 4 gauge to my capacitor and then 8 gauge to my amps. Which i think is ample.
My next step was to mayb mount my mono block off the piece of timber using four feet to allow air flow under the amp and reduce the build up of heat. I even looked at the option of installing a fan to draw heat away from the amp. However, each time my amp has cut out i have often felt the casing of my amp and it has not felt hot in any way.
So thats the story guys.
I hope to hear from some of you soon.
Rowan
