Well since it uses the same board as Soundstream XXX15000d and possibly the Cactus Sounds ELT.12 I thought I'd paste up this quote I found on another forum.
XXX-15000D
Since the 80s, manufacturers have been doing anything they can to generate new hype to sell their amplifiers. Super low impedance stability, over rating, under rating, birth certificates, etc… Until recently, there was no adopted standard for power specifications. Even now, there are ways to cheat the system. When you have a badass product, you don't need to play these games!
Our newest and largest amplifier we've ever built is the XXX-15000D! Appropriately rated, this beast will live up to its name. So why did we make such a huge amplifier? Because there are psychos out there that want it, that's why! Plus, it is cost effective and easier to run a single 15k amp than it is to run (3) 5k amps, (6) 2.5k amps or even (15) 1k amps!
It takes power to make power, so plan on having a strong power supply if you want to be able to use the XXX-15000D to its full potential! This is critical! The rail voltage is +/- 140 volts and we use all “N” Channel MOSFETS. While the amp is 78% efficient, at full power, it can draw up to 1400 amps. Idle current draws a mere 8 amps. You can feed the amp with a 6 volt signal input. The damping factor is >1000 at 100Hz. The PWM module is separated to avoid noise. Just to keep the board stable and structurally sound, we had to use a 2.5mm thick PCB which is 57% thicker than the typical 1.6mm PCB. So, what does the behemoth weigh you might ask? Over 83 pounds! That heavier than most SPL monster subwoofers.
This amp was specifically designed to run at 16 volts for the hardcore SPL competitor. Running the amp at lower voltages will result in less power. With a typical 14.4 volt power supply and powering a 1 ohm load, the monster yields 13kW at 1% THD and
14.8kW at 5%! For the serious competitor with a 16 volt system, the power increases to 14.4kW at 1% THD, 16.4kW at 5% and even up to 19kW at 10% for the guy who doesn't give a crap about sound quality and only needs sheer power!
Other features include 4x 1/0gauge “+” inputs, 4x 1/0gauge “-” inputs, 2x 8gauge remote inputs, and 4 pairs of 8gauge speaker outputs. The subsonic filter is variable from 10Hz-50Hz. The bass boost from 40Hz-120Hz is variable up to 18dB. Low-pass crossover duties are also variable from 35Hz-250Hz.
The XXX-15000D is the most powerful amplifier on the market. But that doesn't mean it has to be ugly. Proud owners can use either the steel bottom or the supplied Plexiglass bottom to show off the intensity of amp guts. So, how big is it? 12-11/ 16” wide, 2-11/ 16” high, and 32-11/ 16” long. Heck, I could surf on this thing! If you think this is a bunch of BS hype and you gotta pair, go try one out for yourself. But don't call us when your skull crushes! One more thing for the competitor with a bolt loose – ear protection doesn't help if your lungs explode and your eyes launch out of your head like rockets! Be smart and use wisely
