Dan_6
Aug 16 2008, 11:38 PM
Hey guys, just need some help with the central locking side of the M80s i am just about finished installing,
first off i would be very much appreciate a picture of the actual central lock loom with the correct colors to compare to the loom i made, and tripple confirm which wire is which, (reason being is that i bough the alarm 2nd hand and it did not come with that loom and i noticed that it was the same as an ATX power supply plug with a few of the pins removed from each side so i made one)
secondly, my car has 2 wire actuators (factory locking) just feed it 12v + and - one way or the other and it locks/unlocks
could someone please enlighten me as to which wires from the m80s i hook to what,
Dan
Dan_6
Aug 17 2008, 11:44 PM
never mind, sorted it out this morning, only other thing i couldnt get to work was to have the interior lights come on when you disarm, saw there was a door + and a door - wire, tried it both ways where i thought they should go but no go, if anyone could help there that would be nice.
Dan
Alex - Formerly Rbimdxe
Aug 20 2008, 10:16 AM
The door +/door - wires are the trigger wires to set the alarm off when a door is open.
What model car? most car's use a negative door pulse(door -ve) AFAIK, so that should be what you need.
To have the interior light come on when the alarm is disarmed/door opened, you need to hook up the Dome wire to the interior light circuit.
