Full Version: WTB - 5 channel amplifier
Mobile Electronics Australia > Trading Place > Car Audio Products > Wanted to Buy
twr7cx
I'm chasing a 5 channel amplifier (you know 4 channels for speakers and then has 1 for a subwoofer). After a half decent brand one (i.e. not a $30.00 eBay special). Not many mobs seem to do them any more, Fusion had the EN-AM10005 until a while ago, and JayCar do the Precision Response 5 Channel Full Range Car Amplifier (<a href="http://jaycar.com.au/productView.asp?ID=AA0458&CATID=24&keywords=&SPECIAL=&form=CAT&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=595" target="_blank">http://jaycar.com.au/productView.asp?ID=AA...mp;SUBCATID=595</a>).
Not interested in anything over $500.00 price range. Preferably after one that's not too physically large either as I need to fit it under a front seat (hence why I'm looking for a 5 channel as there isn't enough room to put 2 seperate amps). The JayCar one linked above is alright size to fit
Post up here, PM me or e-mail me to get the ball rolling if you've got one to offload.
WhiteKnight
zx750.5 kicker amp would do the job too....
purple5ive
there an alpine one (i think ) on ebay atm
Chemhaz
Space saver -
ADS PH15 - 6 Ch amp will fit.. $350
If you can shift your gear to the boot I have the following larger amps which will be more than adequate for your needs -
PPI 5440, 5 ch amp, A1 condition used in box $400
Magnat Combat 6 ch amp, brand new in box $400
Crossfire VR705D 5 Ch amp, 4 are AB, the mono chanel is digital A1 condition used $400
They are all working perfectly, you can find the specs for most of them online
twr7cx
The PH15 doesn't have any inbuilt crossovers or anything now does it? No good then as can't run my small subwoofer in the passenger door off it then.
Definately interested in the VR750D though, however, need to measure up to see if it can be made to fit.
Chemhaz
QUOTE (twr7cx @ Aug 20 2008, 07:37 PM) *
Correct the A/D/S PH15 is amplification only (and gain adjustments) no crossovers. Sounds like your ruinning it off a front /rear output only, you should invest in a 3 way out headunit or an in dash processor to control all your gear up front
twr7cx
Head unit has 3 sets of RCA outputs. The subwoofer set goes to my Kicker amp in the boot for the 15". The front and rear set go to my amp under the seat for the front and rear speakers and the 8" subwoofer in the passenger door.
waxdass
i have a Signat 5-channel if your interested (along with a complete boot install for a wrx)
$400
in Perth
Gozza
Soundstream XTA600.5
180 Watts x 2, 240 x 1 RMS @ 4 Ohms
45 Watts x 4, 120 x 1 RMS @ 4 Ohms
90 Watts x 4, 240 x 1 RMS @ 2 Ohms
new
yours for $450 neg.
