Full Version: Amps with bandpass crossovers? / PXA-H701 questions
WIGARUS
Hi, I'm just wondering what my options are for 2 and 4 channel amps that are able to be bandpassed?
The ones I know of at the moment are the DD S4 and the Zed Audio Draconia.
Just looking for a couple of alternatives...
crosspug
SPL Dynamics "S" series have bandpass xovers. Not that I've used/heard them.....
Jono
_Anthony_
Head unit can't do it? Much easier if you can do it from there.
WhiteKnight
DLS CA-40
WIGARUS
Na, head unit can't do it... I have an AVN6000, so I'm going for a combination of an RF 3Sixty.2 and a decent amp with bandpass crossovers...
Matt VIP
eh wot?
when did the 360.2 lose its crossovers?
" 6-channel high-level input
6-channel RCA level inputs (FR/FL/RR/RL/Center/Sub)
Independent 31-band EQ for Front Left and Front Right
Independent 27-band EQ for Rear Left and Rear Right
27-band EQ for Center
10-band subwoofer equalizer
6-channel HP/LP/BP/AP adjustable crossover
Up to 5 feet of delay per channel in 2 inch increments (subwoofer excluded)
Auxiliary RCA input with 31-band adjustable eq
Auto equalization with auto sum capability
Digital Signal Processor with OEM integration capabilities (patent pending)
Remote programmable master volume/aux volume control
Wireless Bluetooth™
WIGARUS
It didn't smile.gif But it has 5 channels with HP/LP/BP/AP adjustable crossover and the sub channel is LP only, so to go 3 way active plus sub, you need another crossover option for the midbass, the midrange or the tweeter seeing as you might as well use the sub channel on the 3 sixty for the sub...
Audison 6.1k has bandpass for some channels
SStealth
Why not get the alpine h701 and controller. Gives you 3 way plus sub and centre. Will solve all your hassles.
Ant
_Anthony_
Might as well just choose your amp and place a cap in line, might be a hell of a lot easier
I think you should buy the right processor to begin with, instead of purchasing the wrong one and trying to compensate for its shortfalls.
WIGARUS
Oh, I didn't know that the H701 could be used with a non-alpine unit...
Would this be a better option than the 3 Sixty? If so, thats the go...
Matt VIP
in that case, I'd be waiting for the Audison BitOne. 4 way crossovers, auto eq and t/a. nice bit of kit if you can get it wink.gif
[edit] actually heres an idea. hows about providing us with a bit more information so we can give rational, informed advice.
1. Budget
2. Gear you already own
3. objectives
4. anything else that might be useful to know
broadz
DLS "A" series and I know ZX or Ti Phoenix Gold both have bandpass Xovers.
3 sixty isnt ideal for 3way+sub.
Its limit it 2way active + mono rears (run from centre output) + sub
I spoke to the RF rep and he suggested using multiple 360.2s to achieve 3way or 4 way active + rears + sub.
But yes, a H701+RUX controller with a decent LOC would be the way to go
WIGARUS
I wouldn't need an LOC would I? I'm not using an oem head unit.
_Anthony_
No you wouldn't, the PXA would use RCA's for a connection to a non Alpine unit
SStealth
As above, no you wouldn't. Just one set of rca's from the 6000 into the left and right input of the h701 and then the h701 does everything else you want. 3 way plus sub and centre, 2 way plus rear and sub and centre for surround. 8 channels you can do alot with. All have T/A HP/LP 31 band eq, para and graphic. This is what you need and I dont know why damon hasnt mentioned it in the other thread yet.
Antony
broadz
oops, read straight over where u mentioned you had aftermarket deck (i was thinking you waned to retail stock headunit)
mad89
PXA would be the best option probably. Or you can get V12 Alpine amps (MRV-F545 or MRV-F345) which have adjustable crossovers. 30-400hz, or 600-8khz with a flick of the 20x multiplier switch.
WIGARUS
Thanks a lot everyone, I will be getting one as soon as I can find one... Then I can just use another PDX which I would prefer to do to keep everything the same anyway...
SStealth
No worries mate. Let us know how it goes.
Ant
WIGARUS
I've read through the manual and from what I can gather, the volume is controlled by the RUX controller unless I have an AInet head unit. Does this mean that the volume on the AVN6000 won't work? or am I just not supposed to use the volume control on the AVN?
The reason I ask is that I have the steering wheel controls connected to my AVN, if the volume control on the head unit won't work after I connect the PXA then fine, but if it still does and I'm not supposed to use it, then I have to figure out a way to disconnect the volume control from the steering wheel controls.
you can use the volume on the AVN, but the PXA will not be getting a constant input - you can then just set the RUX volume like a 'gain' on the amp - so it doesn't distort.
RMA
QUOTE (Pulse-R @ Sep 3 2008, 06:09 PM) *
All Audison amps in SRx, LRx & VRx can be band passed.
Either by on board crossovers like LRx 6.9 which can be band passed on all channels or in the case of 2 channel amps via a bypass output.
WIGARUS
Thanks Pulse-R, Shiny_car actually answered that for me in a thread I started in general mobile discussion. I probably should have started this one there...
QUOTE (RMA @ Sep 20 2008, 12:55 AM) *
LRx6.9 - that's the one I was thinking... thanks Phil
