Item Condition: Excellent
Reason for selling: Upgraded
Price: $440 each plus postage, $850 for both ono
Payment Method: Pickup - Cash, Paypal
Extra Info:
RMS Stereo power @4ohm Watt 230 x2
RMS Stereo power @2ohm Watt 390 x2
Dynamic Stereo power @2ohm Watt 475 x2
RMS Mono bridged power @4ohm Watt 800 x1
RMS Mono bridged power @2ohm* Watt 1250 x1
Min. Stereo impedance load Ohm 2
Min. Mono bridged impedance load Ohm 2*
Damping factor @4ohm - >400
Input sensitivity range mV 0,174,3
Input impedance Kohm >11
Crossover [quantity] type - [1] HP + [1] LP
Crossover cut frequency range Hz (HP 20150)+(LP 45300)
Crossover slope dB/oct. 12
Frequency response -3dB Hz 10160.000
THD distortion @1KHz - 90% 4ohm nom. power % <0,02
DIM distortion - 90% 4ohm nom. power % <0,03
Signal/Noise ratio - 10Hz22KHz - 90% nom. power dB 104
Signal/Noise ratio "A" weighted - 10Hz22KHz - 90% nom. power dB 106
Power supply range Volt 10,516
Minimum cable size for 5 mt. long - Metric sq. mm 21
Minimum cable size for 5 mt. long - US AWG 4
Max current requirement Stereo @4ohm A 46
Max current requirement Mono bridged @4ohm A 84
Idle current A 1,32
Standby current mA 2
Fuses A 3x 30A
Weight Kgs 4,6
Dimensions L x W x H mm 220x550x50
*Subwoofer load
Pictures:
