QUOTE (200SXGUY @ Aug 30 2005, 10:00 PM)
Try Jaycar super tweeters.
you could also try retreads on your porsche.
wait until the Z's are installed and see what you think. i'd expect the soundstage to be open and high if done well. adding ambients can lift the stageheight but whether you can justify the cost is another thing.
what it takes is:
*suitable 2-channel amp (or spare channels)
*suitable HP filter: is use 10kHz with 12dB/oct slope
*suitable attenuation: simply set the gain properly
*suitable tweeters: ideally exactly the same tweeters as your splits; maybe consider some from the boston pro series
*installation: should be simple enough
given all the hassle...just wait and see.
