Full Version: oh bugger! need opinions asap pls
aspro
can anyone tell me all that could go wrong if the posative and negative power wires were touching after removing an amp? don't know if there was a fuse or not so any and all possabilities of the damage would be great to know
thanx
bugger
[ June 03, 2003, 09:57: Message edited by: wakethedead ]
Poida
Unless you've burnt your car down you should be right
I've done that before, and nothing was damaged...worst case is that the battery might have copped some damage IMO
the[K]id
Check that the battery still holds a charge (check it with a multimeter when you park it at night, and next morning before you start the car, shouldnt be a noticable drop, 0.1V maybe). Apart from that, no biggie, as long as it was only a few seconds. Starter motors are a near short anyway, as far as batteries are concerned.
Mr_Bob
if they stay together, either the wires will melt and the car will burn to the ground, or the battery will explode.
if they just brush together then it'll spark.
rather than asking us this question, maybe you should be asking yourself why they weren't fused!
aspro
well its not my car and i didn't see it happen but he told me that it caught fire and cost him $105 to fix the stereo or the wiring or something , so i just wanna know weather hes bull*****ing me or not. so what could possibly happen to it?
[ June 03, 2003, 12:45: Message edited by: wakethedead ]
the[K]id
Without a fuse its possible to do a bit of damage if wires are left shorted long enough. Fire, blown battery etc. Lots of fun...
aspro
and what about if the car gets started?
is that any worse?
the[K]id
I hope this are all "what ifs" or I'm getting scared!
If it was a really good short (decent connection, didnt burn the wire out etc) then I'm guessing you would have trouble starting the car. Not to mention the obscene voltage issues you would have...
DrEvil
The wires may have sparked which caused the carpet to set on fire
aspro
could there be any other wiring problems?
thanx for the info btw
somethiing aparently happened but not sure what
[ June 03, 2003, 14:55: Message edited by: wakethedead ]
dasherhalo
I personally like to hook the battery up BACKWARDS. That’s a favorite party trick: only cost me my Alpine EQ and the fusible link……
Rattlehead
That happened to me when I was removing an amp to change from 8ga to 4ga cables...I unhooked everything, went to get out the car and on getting off the seat, the cables managed to find each other and spark. That was it though - I was quick to get to it. Dunno what would have happened if I let it sit there while having a beer.
BEART
When i was installing my stereo into my old car my mate connected the amp power wire to the battery as soon as the wires where laid in the car, then with out noticing the wire touched my tow bar and all of a sudden my other mate turns to me and we both ask each other if we had farted then all of a sudden smoke was coming out of my car because all the plastic insulation had melted and half the wire and it almost burnt my carpet
