Hi guys,
My F540 (4x50rms @ 12V) has quite a flexible crossover, with both a selectable high-pass and low-pass on each pair of channels
the high-pass can be set to either:
- 15Hz-400Hz at 12db/octave.
- 300Hz-8kHz at 12db/octave (using a x20 frequency multiplier switch).
the low-pass can be set to either:
- 30Hz-400Hz at 12db/octave
- 600Hz-8kHz at 12db/octave (using a x20 frequency multiplier switch).
My headunit is a Clarion DXZ935, which has an inbuilt:
- high-pass filter at 50/80/120Hz at 12dB/octave for front and rear channels.
- low-pass filter at 50/80/120Hz at 18db/octave for subwoofer channel.
- Parametric EQ with 3 bands for each front/rear pair.
- Time alignment for each individual channel.
Will the amp crossovers be sufficient to run an active front stage using the front RCA's for tweeters and rear for woofers? I am concerned with the quality of the crossovers and the 12dB slope?
I want to do this so I can separately purchase my woofers and tweeters for a "custom/DIY" front stage with the likes of Peerless or Seas woofers and a Vifa tweeter. This will save money by not purchasing a premade passive crossover network, and allow my to buy premium drivers for a good price.
Also running the tweeters and woofers on separate channels will allow me to use the DXZ935's 3 band parametric EQ separately on each giving me in effect 6 bands over the whole frequency range. Also I will be able to alter the time alignment between the woofer and tweeter to compensate for any mounting compromises.
Will the F540 inbuilt crossovers allow me to do this (and do it well enough to justify the effort)? Also this obviously introduces the cost of another amp to run the sub, instead of leaving 2 channels for bridging if I was running conventional splits and passive crossover.
