QUOTE (supa-roo @ Sep 10 2005, 10:00 AM)
colder air from tests i have seen doesnt really do to much on an atmo engine, power wise. most of the gains from fitting cai kits, seem to be just from better/more air flow rather then cooler air
yes, i'm aware of that. You also get a damn nice induction noise on WOT.
And technically, it does make a minor difference, so why not do it?
QUOTE (>WAYCON< @ Sep 10 2005, 12:16 PM)
Indeed - a proper K&N high-flow filter in the end will be the only thing which offers a substantial (noticable) gain in your performance.
That said the CIA has been said to offer minimal fuel ecconomy benefits and reduce engine wear - so if you are going to do it properly you may as well duct the air from somewhere cooler than the engine bay.
Just make sure that the intake isn't anywhere likely to go underwater and she's all good!
I'd contest that, but only for my particular model car.
Theres been a few interesting studies around the place that showed that while removing the ducting from the filterbox > out did indeed reduce the intakes airflow restriction, leading to a technically provable increase in economy, replacing anything from the filterbox back did nothing, in fact in one instance it decreased economy, airflow, and HP. Albeit minimally.
Also, aftermarket filters, for lancers (especially the K&N) have been shown to do one of two things
1) Flow more (but not much), but filter drastically less (about 60% filtering effeciency compared to a lancers OEM panel filter).
2) Flow less, and filter drastically more. = restriction.
Seems the filterbox < BACK assembly on lancers was made pretty much spot on.
That said, an aftermarket kit will again make the induction noise louder than just doing the CAI part.
OEM design can really suprise you sometimes, another example that pops to mind is the toyota supra's MK4 B.O.V (a tiny, fragile looking thing) outperforming most aftermarket B.O.V.s. hehe.
