Full Version: Which Amp For Best Sq?
TF-LAD79
After opinions on amp to choose....
Mainly after SQ.
Deck will be a Alpine 7969r, which from what ive been told is a top sq deck.
Spkrs will be
front - focal polyglass 165V2 splits
Rears - Eclipse 6x9s (yeah I know not very sq, will be rremoved later with addition of either 2 x Boston Pro 12.5 or 2 x Type X 12's subs.
question is which amp -
Alpine MRV-f340 55rmsx4 @ 4ohms
(0.08%)thd
or
Eclipse EA3422
50W 4 Channel 0.1% THD at 4 Stereo @13.8V
(RMS Continuous Power)
or
Phoenix Gold Octane-R 8.0:4
Which is rated at 125rms x2 @4ohms
(1%)thd
thanks heaps for any advice.
Luke
Kev
Um I would choose the PG but for no real reason, I just prefer them over Alpine. Do you have any other choices? Is it 4 channel amps for the rears or for a sub? If its 4 channel for the 6x9's then spend the money on a decent 2 channel amp and run the rears off the deck and SQ wise (well arguably everythingwise) it will sound a lot better. smile.gif
Redlined
i would choose the alpine, the pg's thd is too high...the spec's for the pg amp is 75rmsx4 at 4 ohms, or 250rmsx2 bridged, trust me, i've got one driving my subs....are you only limiting yourself to these two?
TF-LAD79
QUOTE (Redlined @ Sep 12 2005, 01:21 AM)
I am but only coz these are both avail to me used for $300 each(limit of my budget after buying the splits, 6x9s and deck.
Luke
TF-LAD79
OK found another contender by Eclipse, how good are they for SQ?
EA3422: 4/3/2 Channel Power Amplifier with ChannelFlex Crossover plus Subsonic Filter
* 123W 4 Channel Max. Power Output at 2 Stereo
* 70W 4 Channel 0.1% THD at 2 Stereo @13.8V
* 50W 4 Channel 0.1% THD at 4 Stereo @13.8V
* ChannelFlex Crossover
* Adjustable High-Pass Frequency
(50–200Hz, L/R Independent)
* Low-Pass Frequency (90Hz)
* Adjustable Bass-Boost Level
(45Hz, 0–9dB, F/R Separate)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
* Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
* High-Level Input – Add on Capability
* Epoxy Composite PCB
* 2 Stable Design
I think its down to this and the V12.
Opinions?
Redlined
you can't go wrong with either the alpine or the eclipse, the 5rms difference in power is negligible and you'll have to make the decision more on cosmetic value
Stooge007
how long is a piece of string?
how about Audison SRx4? DD C4?
you probably won't hear much of a difference in the amps you have listed. speaker install and sound deadening will affect sound alot more
- Stooge007 out
TF-LAD79
yeah I was chasing a SRx4 but just missed out on it.
problem is my budget is limited to $300 +postage
Luke
VtirBoy
Hey bro i sent you a pm! Reply it
DRAGON@WORK
I would also suggest trying to find an audison srx 2nd hand (in decent condition)
