Com_VC
Jun 13 2003, 07:03 PM
Well I have an efi intake manifold pretty much the same as the one shown below and i'd like to remove all the paint from this so I can polish it up to a shiny finish as it's made from alloy.
Anyways I was browsing through the latest Super Cheap catalog as you do and noticed that they had an air sand blaster kit for $25 do yous think it would work alright for my purpose? I have a compressor already so that aint a problem. Would i need some sort of abrasive to use with this to remove the paint, what type do i use?
http://gallery.oldholden.com/albums/EFI/DC..._1509.sized.jpgthanks in advance
Com_VC
Jun 13 2003, 07:06 PM
actually can a moderator please move this to open discussion.
thanks
Com_VC
Jun 16 2003, 08:40 AM
anyone know?
Walkinshaw
Jun 17 2003, 04:00 PM
you have a VK EFI manafold on your VC?
anywy, paintstripper would be easier/cheaper
Courtancer
Jun 17 2003, 05:15 PM
Sand blasting won't really give you a shiny finish. It will give you a dull finish more similar to an annodised looking surface. That could look good too though. I'm sure you could find more uses for a sand blaster if you got one but depending on how good the sand blaster is, it may be easier to do as mentioned above.
mirage
Jun 18 2003, 07:34 PM
what im doing to the underside of my car (you can see in my signature) is using an anglegrinder and knotted wire wheel attachment.
Will do what you want, leaves a shiny finish and is simpler and tidier.
