MiKe
Jun 19 2003, 02:20 AM
hey
i have a laptop and a pc both with 10/100 network cards
i have no idea how to network
is it as easy as buying a network cable (cat5?)and hooking the 2 computers up?
can i share internet connection (dial up) between the 2 computers?
thanks
mike
nemesis
Jun 19 2003, 02:39 AM
what operating system? do you have a hub/switch?
Mr_Bob
Jun 18 2003, 03:03 PM
you'll need an internet gateway/router or a product called wingate. (or equivalent)
to share the internet connection,
to network them you need the cable and a bit of setting up in windows.
Sigmeister
Jun 18 2003, 03:05 PM
Just buy (or make) a crossover cable. One end in one computer, the other end in the other, can't be any simpler than that. Other than making sure network settings are correct
MrMonaro
Jun 18 2003, 03:21 PM
Yes you can do it without a hub and yes you can share the internet. If you have any problems PM me and i'll sort ya out
The first thing you need is the network cable, if you dont have a hub you will need the normal cat5 (RJ45) cable, but it has to be crossover cable, its different to normal stuff.
Give both computers the same domain , IP's such as 10.15.13.1 and 10.15.13.2
go into your "my computer" right click your drives and share them. And should be good.
galapogos01
Jun 18 2003, 03:23 PM
as long as the computer doing the internet sharing has windows 98se or newer, you can use Internet Connection Sharing from within windows and a crossover cable to link two pcs. any more and youll need a hub... a crossover cable should not be more than $20. look at the online help for ICS for more info, its easy to setup.
MrMonaro
Jun 18 2003, 06:03 PM
windows'es internet sharing program in my opinion sucks the big one. Wingate, or Winproxy - i recommend winproxy can be used. You can download a tiral version from either of their websites
MiKe
Jun 18 2003, 08:20 PM
thanks for all ur replys so far
ok
computer 1. is running XP pro
Laptop 1. is running XP home
computer 2. is running 98
the internet is accessed on computer 2., but can i think it can also be accessed on laptop 1.
i have no router or switches
whats the best way to go
-buy a router/switch/hub?
and will the way i set it up be affected if i get broadband
mike
