First of all, thanks for all the help you guys have given me. Based on your recommendations when I first joined this site a few months ago, this is my system as it stands:
System 1. I am very pleased with the way this system sounds, however there is no subwoofer and no midrange driver. I can compensate for the lack of bass by turning up the EQ, but that just muddies up the midrange and there is still no true low-down bass. So I need a subwoofer. The mids and highs sound a little bit bright, and there is audible seperation between the MD-130 and the MW160GT - as in, I can hear the spatial difference between the two speakers. So a midrange driver is in the cards. To power my new speakers, I will need to purchase a new amplifier.
So after nearly $3500 worth of parts and install I should end up with this:
System 2. You will notice there is no crossover in this system - I am running it fully active using the built-in crossover in the DEQ-P9R. From my reading elsewhere, there are a few advantages of a fully active setup:
1. Improves amplifier damping
2. More power
3. Less heat
4. Fewer electronics = better signal purity
However my installer believes that passive crossovers sound better. This is a bit counter-intuitive to me - I am wondering how putting MORE electronics in front of your signal path can possibly improve the sound? Anyway, this is the system he is proposing:
System 3. As above but with custom passive crossover. This would add a further $1000 to the cost!!
What do you guys think? Is it worthwhile going for the custom passive x-over?
