QUOTE (aj2thec @ Oct 21 2005, 12:21 PM)
25mm will give you optimal results but the box will be that heavy you'd notice it when driving.
FYI, I'm about 90% done on a box for a 3512 and i'm using a combo of 6, 12 and 18mm and f/glass.
If you take your time, build it right and use some clever bracing you'll get away with 18mm.
The difference in weight between a 16mm box and a 25mm box would be less than 5kg. If you can "notice it when driving" your car must have around 20kW.
The more dense, the more rigid, the more solid the box, the better it will sound. Honestly worrying about 5kg is nothing. If you must try and set a world record at the drag strip, you can always take the box/woofer out.
