I have a JL 12w3v2-D2, in a box that I purchased with it.. It was purchased from Doran Audio in Sydney.. Not sure on the spec's at all, but it's a pretty big box..
reason for this post is, I'm looking at making another box/install for the rear of my car, to make it a bit tider, and hopefully the box a bit smaller...
something that looks along the lines of this:
and
I'm after a set of box dimensions for the sub... the specs of the sub are as follows...
Free Air Resonance (Fs): 24.3 Hz
Electrical “Q” (Qes): 0.475
Mechanical “Q” (Qms): 8.483
Total Speaker “Q” (Qts): 0.449
Equivalent Compliance (Vas): 3.65 cu. ft. / 103.4 liters
One-Way, Linear Excursion (Xmax)*: 0.513 in. / 13.0 mm
Reference Efficiency (no): 0.300%
Efficiency (1W/1m)**: 86.7 dB SPL
Effective Piston Area (Sd): 81.5 sq. in. / 0.0526 sq. m.
DC Resistance (Re): 3.82 ohm***
Nominal Impedance (Znom): Dual 2 ohm
Thermal Power Handling (Pt): 300W
Driver Displacement: 0.07 cu. ft. / 1.98 liters
Net Weight: 11.2 lbs. / 5.0 kg
thanks for any help !
