Car ran fine before this install was done.
thats my point in ran fine BEFORE this install
even had a Boss 1200 amp running two 15's.
And most peoples front stages probably make more power than any Boss amp
how exactly do i do 3-4 runs of 0g? the amp can only fit one 0g wire in it?
You really wanna know.???
These pics are
just from my Street A car, a class where we are only allowed 2 amps max, there is 20m of Stinger 0g all run thru the factory firewall without any need to cut any metal.
Like this:
and this:
even like this:
and this is soft compared to cars over in the states and Europe where its common place to use as many as 16 runs or more..........
Now im not an expert but i know my electronics. upgrading the wire can only do so much. it cannot give me power that is not there.
True, but it will help maximise the delivery of the power you do have from the battery to the amp, more cable gives the current more surface area to travel on, hence getting the power to the amp/s quicker.
In SPL the idea being to make as much power availble in a very short time frame multiple runs of 0g are common place in the cars of the more serious competitors.
but he reccomended getting a few good deep cycle batteries
He said run 3-4 100AH Deep Cycles in parralell.
You say
The alternator cannot be upgraded (way too much $$$$)..
Do you realise how much it would cost to get 3-4 deep cycle batteries??
Plus IF your alternator is on its way out, it wont be able to charge 1 battery properly let alone 3-4.
He reckons using this system for SPL Comps will just kill the batteries.
The point that both Blackice and myself were getting at is that we both run big power set ups ( with the Crown capable of like 6000rms and my pair of Eaudios the same) off only one battery, without any other mods like Alternator upgrades and dont have any issues.
Both cars are also daily driven.
I say upgrade the cable, then look at getting that Alternator checked out.
