Now get yourself an ADAT and 3 bands of dynamic playback to connect console and poetics
care to elaborate on that a bit more
im stiil trying to work out the best way to set it up, i am at the moment running just a tone or a bunch of different ones from my keyboard to the main input and using the spare output from my pc setup wilst playing a beat etc to trigger its filters ... or something similar to that
haveanyone here had experience with one of these?
LMAO @ tounge on plug comment thats one of the funniest things ive heard in a long time what made you decide to try that?. Whats the maximum input voltage sensitivity like?
up to 10volts of input voltage, what is cool is that if you turn down the occilator to minimum it cycles about every 5min! to get a true bypass you have to use a foot switch
what made me try this? i was after something different, for those who don't know its a sherman filterbank 2, a true analog distortion unit and freq occilator, here is more info
sherman at first inspection it seems like just a bunch of knobs and you fiddle with them and make cool sounds but its not untill you really start using the triggering inputs etc that you realise its real power! its sound is incredible, rich and it can go from a warm clean tube sound to crunchy 'marshall' sounding overdrive to a full on screaming mess, enough high freq to kill any tweeters(thank god for horns
) and lo freq that can go to below 1hz!! if you want them to, then with then by feeding a music or beat to the triggering inputs you can crate rythmic type tunes very industrial/heavy acid style dirty sounds, it great!
there a bit expensive though but there is one left in aust that can be had for a good price
once its gone you have to wait till they make more, there only made in small batches by like 3 people in a small company in belgium or something
