QUOTE (Elmo @ Nov 3 2005, 04:35 AM)
What vehicles will this exact supercharger kit be suitable for?
I could be interested.
What car do you have ? Its just a matter of brackets, drive belt and pipe work to fit it as is.
Its a bracket mounting supercharger (like an alternator), so it can be adapted to pretty much anything from 1.3 up to 4 litres.
Toyota guys use this as an upgrade for their 1.3l 4AGZE.
This unit came from a 2litre Toyota 6 (1G-GZE).
Castlemaine Rodshop makes the bolt on kit to adapt this bad boy to suit Holden V6's.
You could mount it on a Ford 6 up to 4 litres with the right pipe work and brackets.
Draw thru the throttle like a normal supercharger.. or you can blow thru the throttle and run a BOV for PSSSSHT on gear changes.
Easy to intercool too !
HKS make smaller drive pulleys if you need more boost.. funnily enough Castlemaine sell them too
