Full Version: Amps under seats
sk8rpnk
I have just bought a new car (1995 Ford Laser Lynx) and i want to put an amp under each front seat. The boot is a last resort as i want to keep all the space for holidays, and drive-ins wink.gif
The problem is that there is an air-con vent on the floor (under the front seats) facing the rear of the car. This is a feature in quite a few cars, so i was just wondering if anyone had found a way around this? Or could give me some suggestions, thanks guys!
bob
Shorten it so its no longer in your way I guess would be your best bet.
Stooge007
how much room is there under there?
could build an MDF tray? although could make the amp too close to the seat, which could = fire sad.gif
- Stooge007 out
aj2thec
QUOTE (bob^ @ Nov 4 2005, 08:15 AM)
I've done that before, cut it short then blocked it off. always a big call when making irreversable mods like that though.
blanketman
the vent should be able to disconnect
just disconnect it before looking to cut it out
stazed
sk8rpnk
Thanks for the replys guys, had a look today and its pretty thin plastic that its made of so im gunna try and wedge the amp underneath it (so the air would flow ontop)
Stooge - the seats are pretty low because theyr sporty ones so a tray is outta the question.
Blanket - do you mean disconnect from just under the seat? or would it be a whole peice from the centre console?
blanketman
they usually connect in several peices
just find the closest one and just detatch it
sk8rpnk
ok mate thanks for that.. at least now i know what im up against and how to fix it biggrin.gif
Dogo
Mine hasnt been cut just sealed off with gaffa tape.
I tested on full power and that air doesnt come out.
I you have hot air blowing over the amp it will still make the amp hot
sk8rpnk
