mzoghbi
Nov 6 2005, 06:39 PM
Hey guys i need a bit of advice ..witch subs better and when i mean better i mean better qualty and has a better bass sound..
i got a choice of a KICKER CVR 800 DUal 2 OHm and a
KICKER CVR 800 DUal 4 OHm
THANKS
Michael
XtothaZ
Nov 6 2005, 07:30 PM
These subs are both the same as in quality, the only difference is the configuration. To answer your question you need to tell us what amplifier you will be using?
If its a monoblock, it will provide optimal power at 2ohms, so the dual 4 ohm sub would be the better option. On the other hand if its a 2 channel amp, with optimal power at 4 ohm, then the dual 2 ohm sub should be purchased.
Hope that helps slightly.. although im sure shiny or someone with more experience will explain it better
mzoghbi
Nov 6 2005, 09:07 PM
Hey dude,
ive got a coustic monoblock amp.. going ot be running it at 2 ohms..
Michael
Stooge007
Nov 8 2005, 07:26 AM
if you're buying only 1 sub, then get the dual 4, so that you can wire in parallel for a 2 ohm load
if you're buying 2 subs, then get the dual 2's, so that you can wire in series/parallel for a 2 ohm load
- Stooge007 out
