Full Version: Novell Help
exup
Hey fellow g33ks.
I know nothing about novell.
At my work we have 2k domains that we logon to. Then we have a server that isnt part of the domain, it is novell 4.11.
I want connectivity with the novell server when it needs it. So I need novell Client.
However, I don't want the Novell Login Screen coming up on boot - I want it as the standard windows 2k logon screen.
Can anyone tell me how to do this ? (on win2k machine)
Cheers!
Mick
good question... ill have a look round and talk to a view guys at work... i seem to remember you can only do it with version 5 and up... dont quote me tho!
Ole'
yeah i'll have a look too
*searches for novell text books*
exup
Cheers Fellas.
I am using client version 4.83. SP2 If it matters. I have searched around the net and can't seem to find anything.
If you guys don't know, would you know a place I might find out?
exup
^bump^
exup
and another ^bump^
how did u go guys? find out anything?
STIK79
Will look when I get back to office monday (might need to PM me to remind me lol!) I thought it wasn't possible but...
exup
it can be done, my pre-deccesor has done it on 2 computers...buggered if i can duplicate it tho
exup
*bump*
still no ideas?
Mick
nah mate, cant find anything!
let us know tho!
STIK79
Um without the novell login screen - how do people specify trees etc??
STIK79
Ummm under Novell Client Properties - advanced menu settings - theres a Enable Login Dialog option that can be set to off? I dunno don't have time to fiddle and test but maybe worth a try...
exup
ok thanx dude, i will try it monday morning!
GHT-251
I have done this in a previous w/station build at work but now someone asks how its done i cant remember.
It was on a laptop so that when your not connected to the network you can still get in and when you need network access you just double click the N icon in the sys tray.
I think i may still have that build stored on our server ill have a look at the settings for you and see if i can pick it out.
exup
yes there is, but no, it didn't work.
thanks for trying - anyone else?
Rolling Thunder, did u get a chance to have a look?
GHT-251
Yes i had a look!
I couldnt find that build im guessing it was deleted.
The best i could find was this:
-Go into your Client config options
-Advanced Menu settings
-find cancel Desktop login and set it to on
-find enable login dialogue and set it to off
-find require initial logon and set it to off
-then right click the Novell Systray icon and select config systray icon and set the double click option to netware login.
This will do similar to what your asking but you have to cancel the novell login screen at boot up and then login using the sys tray icon.
Im buggered if i can remember what we did to get rid of it.
It might even be server policies causing the disable login dialouge setting not to work.
anyway ill keep looking.
hope this helps a bit.
[ July 21, 2003, 15:53: Message edited by: Rolling Thunder ]
exup
ok thanx. I might have to settle for that for now.
Dam this is anoying the hell outa me. i hate not being able to do stuff sum1 else has been able to do.
cheers, if you guys find nething, let me know
i will let you know if i work it out.
does any1 know a good novell forum ?
GHT-251
FINALLY I found the build stashed very well away heres what you have to do.
First copy all the Novell client install files to a local Hard disk.
Then open NWSETUP.INI in the client setup directory.
Find a paragraph called [PrimaryNetworkLogon].
Change it to NO.
now reinstall the client from where you copied the install files and reboot.
This will stop Novell from being your default Login GUI at boot up.
Then just set up the settings i said in my other post and you should be right.
exup
mate, u = legend!
i will give that a go later today or tomorow
thanx heaps!
