QUOTE (jas @ Nov 11 2005, 12:00 AM)
5khz @ 18db/oct???
i would only venture there if you were using a 3inch or smaller dome mid...and even then i would use 12db/oct or even look at 6db/oct
now x-over for the tweeter is more dependant on the mid. If you use carbonfibre, kevlar (any focal mids), titanium, aluminium (any metal) then i would use something like 18 to 24db/oct around the 3khz region give or take 500hz.
paper and plastic (including dyns) tend to be more forgiving with breakup nodes. there for they are more suitable to 6 & 12db/oct slopes.
yes the "D" 710000 has a better f/r 30degrees off axis+++ and is cheaper than the "R" 700000. For the automotive enviroment i would say the 30degree off axis graph is more important in general than the 0degree. This is not home audio we can not sit in the ideal location or place the tweeters in the best spots most of the time. This is why i place more enphasis on the 30degree off axis graph and would choose the "D" 7100000 over the "R" 700000
D = dome
R = ring for scanspeak drivers
let us know what mids you are using then we might suggest a STARTING point for the x-over point. But you will still require proper tuning to get it right.
OK, I'm using Seas Excel 5" magnesium cone mids (code: W15CY001). Can you recommend the appropriate x-over cut-off points for them?
I may be mistaken, but from what I gather one should not rely too much on frequency response graph provided by the manufacturers because the environment that the speakers are gonna be used will affect how they sound. When tested inside an anechoic chamber the speaker driver may exhibit a rising frequency response for example, but upon using it in a car door or placed on the dash its response is considerably altered.
From my own experience, using a lower HP filter on the tweeter made the sound more "telephony-like" and harsh, hence the 5 kHz@18db/oct. Plus, I read it from somewhere that for a-pillar mounted tweeters 5 kHz HP filter is a good starting point, or even 6.3 kHz...ah, I remember now, it was Scott Buwalda who made the suggestion. And you know what? With my equipment, how the tweeters are positioned and aimed, taking into account my sonic preferences.......he's right.
But nevertheless, I am welcome to suggestion on just about anything car audio related so feel free to educate me.
Cheers,
Bon
