QUOTE (stazed @ Nov 14 2005, 09:09 AM)
Actually Maz I disagree about calling the test pointless.
Yes it is pointless.
Say you had two Dual 1ohm 9515 subs
Wire all the coils in parallel and at 0.25ohm they get say 150db. Run them all in series at 4ohm they get say 142db. All the test proves is that in parallel the amp put more power into the subs so they went louder.
We need far more data to turn the ripped results into information. You cant just go by the rule that 3db is double the power, as in the real world this isn't always the case.
If we knew how much power each the 1015 was getting on each burp due to the higher impedence and then turned down the gains with the other sub so they both had the same power, then the results would be much better.
